Is it possible to calculate the volume 'V'(from the measured height 'h') of a lying cylinder with ESPEasy ?
Has ESPEasy mathematical functions like ARCCOS ?
Formula: V = r²*l*(arccos(r-h/r) - (r-h)*√(2*r*h - h²)/r²)
Volume of lying cylinder
Re: Volume of lying cylinder
No not currently, could you please add it as a feature request on GitHub?
Sure...
Why not curve fitting in the meantime.
Google for a percentage fill table > curve fit choose adhoc curve fit et voilà accurate enough for at home.
HI need this too? any news about this request?
many Thanks.
Raphi
many Thanks.
Raphi
Here's my solution (polynomial function 5. grade instead the ARCCOS-formula):
Device1: JSN-SR04T, Name: Fuellstand, Valuename: WertRelativ, Formula: ([min-cm ]-%value%)/([min-cm]-[max-cm])*100
Device2: Dummy-Device, Name: FuellstandZylinder, ValueName: FuellstandZylinderRelativ
Rule to calcute 0-100% height to 0-100% volume:
The value from the second device is published via MQTT to my OpenHAB-Server.
On Fuellstand#WertRelativ do
Taskvalueset 2,1,-0.1428+0.290825*%eventvalue%+0.0285366*%eventvalue%^2-0.000428633*%eventvalue%^3+0.00000356523*%eventvalue%^4-0.00000001419964*%eventvalue%^5
