Button to toggle RGB leds
Tecumseh
#1 Post by Tecumseh » 06 Nov 2018, 13:02
I am trying to create a selection toggle switch for my wife to operate a series of RGB leds. For this I want to have a button and on press cycle through a series of colors. What I did was create a variable with the Generic Dummy device and I can increase that value with a buttonpress and above a certain value (9 in my case) reset it to 0. What I don't have is a swift response on the rgb led, I currently change that based on the variable value but that change seems to take a long time until discovered. What can I change to have a prompt result after button press?
on Touch#Button=1 do
  if [Var#Color]>9 do
    TaskValueSet 3,1,0
    TaskValueSet 3,1,[Var#Color]+1
on Var#Color=0 do
  neopixel,1,0,0,0 // Off
on Var#Color=1 do
  neopixel,1,255,0,0 // Red
on Var#Color=2 do
  neopixel,1,0,255,0 // Lime
on Var#Color=3 do
  neopixel,1,0,0,0255 // Blue
on Var#Color=4 do
  neopixel,1,255,255,0 // Yellow
on Var#Color=5 do
  neopixel,1,0,255,255 // Cyan
on Var#Color=6 do
  neopixel,1,255,0,255 // Magenta
on Var#Color=7 do
  neopixel,1,128,0,0 // Maroon
on Var#Color=8 do
  neopixel,1,128,128,0 // Olive
on Var#Color=9 do
  neopixel,1,0,128,0 // Green
Re: Button to toggle RGB leds
#2 Post by grovkillen » 06 Nov 2018, 15:57
Use task run command right after setting the task value for it to trigger the event.
Tecumseh
#3 Post by Tecumseh » 07 Nov 2018, 00:13
Thanks, that worked brilliant. Here's the complete code used (device 3 is the dummy device)
  if [Var#Color]>8 do
    TaskValueSet 3,1,0
    TaskRun,3
    TaskRun,3
on Var#Color=0 do
on Var#Color=1 do
on Var#Color=2 do
on Var#Color=3 do
on Var#Color=4 do
on Var#Color=5 do
on Var#Color=6 do
on Var#Color=7 do
on Var#Color=8 do
on Var#Color=9 do
#4 Post by grovkillen » 07 Nov 2018, 06:03
Great news :)
dynamicdave
#5 Post by dynamicdave » 13 Nov 2018, 08:24
Which version of ESP Easy are you using?
I've been trying to make use of your rules with the November,2018 releases of mega-espeasy.
It would be interesting to know which version/release you have used.
Cheers from David.
Tecumseh
#6 Post by Tecumseh » 13 Nov 2018, 10:14
This unit runs on version mega-20180914, I'll update it tonight and see if that makes a difference
Tecumseh
#7 Post by Tecumseh » 13 Nov 2018, 19:13
Some bad news, I have just updated this unit to the latest nightly build (ESP_Easy_mega-20181112_normal_ESP8266_4096.bin) and now the ruleset is not working anymore.
Looking at this bit of code from the rules section:
  if [Var#Color]>8 do
    TaskValueSet 3,1,0
    TaskRun,3
    TaskRun,3
It looks like TaskValueSet 3,1,[Var#Color]+1 is being read as TaskValueSet 3,1,1, after changing this line to TaskValueSet 3,1,[Var#Color]+2 I am getting the next color in the sequence (variable 1 from device 3 is set to 2).
*edit*
After loading firmware ESP_Easy_mega-20181021_normal_ESP8266_4096.bin I have this functionality working again. Also tried version ESP_Easy_mega-20181107_normal_ESP8266_4096.bin but that one didn't work. I'll try to find the latest version when this still worked.
*edit 2*
After some trial and error I can report that ESP_Easy_mega-20181031_normal_ESP8266_4096.bin is the latest version where this feature works.
dynamicdave
#8 Post by dynamicdave » 13 Nov 2018, 19:52
Well that is eaxctly the same as the problem I'm seeing.
None of the November releases work with the incrementing a named-variable in the rules.
I agree with you, that the last version that works is 2018-10-31
Thanks for taking the time to check this out.
Cheers from David.
Domosapiens
#9 Post by Domosapiens » 13 Nov 2018, 20:20
Using mega-20181101
this part of my rules works !
TaskvalueSet,3,2,([MUC19NAN#MUC19_NAN]+[rot#counter]/10)
Is using ( ....) these brackets the trick?
dynamicdave
#10 Post by dynamicdave » 13 Nov 2018, 20:48
Thanks - I'll give that a try tomorrow (as one of my students has borrowed the node with the NeoPixels this evening).
Cheers from David.
Tecumseh
#11 Post by Tecumseh » 13 Nov 2018, 21:00
Using the latest nightly build and the following code still no success:
  if [Var#Color]>8 do
    TaskValueSet 3,1,0
    TaskRun,3
    TaskValueSet,3,1,([Var#Color]+1)
    TaskRun,3
dynamicdave
#12 Post by dynamicdave » 13 Nov 2018, 21:04
Oh that's annoying - I thought the hint about (....) made sense and would solve the problem.
Thanks for trying it out.
PS:
I've just noticed that on line-3 you have TaskValueSet 3,1,0
and on line-6 you have TaskValueSet,3,1,([Var#Color]+1)
i.e. one with a space and one with a comma.
I'm clutching at straws and trying all sorts of combinations to get this rule working.
if [Var#Color]>8 do
TaskValueSet 3,1,0
TaskRun,3
TaskRun,3
Tecumseh
#13 Post by Tecumseh » 13 Nov 2018, 21:34
dynamicdave wrote:
13 Nov 2018, 21:04
PS:
Yes on another forumtopic I saw a comment (from you I think) that it was better to use the comma then the space as currently the spaces are interpreted as comma's but that could change in the future. Therefor I made a couple of changes in the code. With the october 31th version that gave me no problem but I figured reverting to the original code for testing version compatability would be best. Must have missed one instance still.
dynamicdave
#14 Post by dynamicdave » 14 Nov 2018, 11:10
Success.... I've been given the answer/reason why the named-variable didn't work in 'rules'.
I got it now! See #1986.
The problem with your rule is that [Var#n] is a reserved command that retrieves the system variable %Vn%.
Wiki should be updated with this new commands and system variables.
