I am developing my first EspEasy project, to controll my bath heatpump with IR led and an ESP-01.
But I have a problem, when I boot the ESP-01 with a IR led attached to GPIO-2 it doen't boot. And if I attach the IR led to GPIO-0 the ESP-01 boot to flash mode.
Any ideas?
Issues with IR Led and ESP-01 GPIO2
Re: Issues with IR Led and ESP-01 GPIO2
I would not use that board. https://www.letscontrolit.com/wiki/inde ... figuration
ops!
is it impossible to use a IR led with ESP-01?
I think the problems is the boot, because if I connect the led after boot it works.
Yes exactly it's the boot that will be causing problems. If you're steady on your hand you can solder directly on the MCU
Let's see if I can explain this a bit.
A GPIO usually can handle an electric current of around 20 mA.
A IR LED usually needs more. I know, some are listed in datasheets
and catalogues with 10 ma or 20 mA... just forget it.
Why?
Because IR data comes in very short pulses. To get a good range for IR commands
these pulses are much higher then the LED's "forward current" from the datasheet.
So a LED connected to a GPIO directly gives a high load to the GPIO pin.
Higher than the pin can take. This way you just "pull down" the pin,
it it set to a logical "low" value.
Logical "Low" on GPIO 0 says "flash mode"
Logical "Low" on GPIO 2 blocks booting.
This is the usual behaviour of the ESP8266!
There's the explanation for your results.
Best way to get out: Use a transistor or FET to drive the LED.
In the Wiki you can soo how to do an IR Transceiver with a ESP-01.
https://letscontrolit.com/wiki/index.ph ... ransceiver
But I agree with Grovkillen: The ESP-01 is pretty outdated and comes with a lot of problems nowadays.
I've set up a newer Version to the Wiki using the ESP-12 / 12E / 12F types:
Both versions are proven to work.
Why?
Great!
Thanks yor for your explaination!
I will test With a transistor (2N2222) or upgrade my board.
Hello again,
Please remember that a transistor in opposite to the FETs I've used
needs a resistor in series with base pin.
A good sample circuit is shown at https://letscontrolit.com/wiki/index.php?title=IRTX
Just as a Hint: Upgrading your board won't change the need for a transistor or FET.
The ESP is not able to give enough current to fully power IR LEDs.
Users browsing this forum: Google [Bot], Semrush [Bot] and 93 guests
