I would like to measure the total time an LED is switched on.
(This is the LED which shows that the burner of my wood pellet heating is active - I'd like to create an operating hours counter.)
I hope to get the hardware part set up using a photo transistor on a digital input of a D1 mini.
While experimenting, I couldn't find a way to measure the on-time of an input.
Is this missing from ESPeasy, or did I just not find the right device setup?
I already tried the pulse counter - but it seems to me that this device was not designed for this kind of task.
I'd really appreciate any hints that might help me solve this!
TIA
Rico
How to measure on-time?
Re: How to measure on-time?
I would do it using a switch input and a timer that is triggered once per minute.
So you mean I should solve this using rules?
Sounds like a good reason to start digging into this topic...
I think I would like to have a slightly better time resolution than one minute - but this will probably work fine every 10 seconds or so, too.
Thanks for the idea!
Yes you could do once per second so 10 seconds is a good number.
Users browsing this forum: No registered users and 98 guests
