Yesterday I was able to succesfully flash and use a Nodemcu V1 with the Arduino IDE, Today it fails after several updated on the Arduino libraries.
The errors I get are:
Arduino: 1.8.7 (Linux), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
WARNING: Category 'LED' in library CHT16K33 LED Matrix Library is not valid. Setting to 'Uncategorized'
WARNING: Category 'Input' in library MechInputs is not valid. Setting to 'Uncategorized'
WARNING: Category 'Input' in library SerialSensors is not valid. Setting to 'Uncategorized'
WARNING: library LiquidCrystal_I2C claims to run on (avr) architecture(s) and may be incompatible with your current board which runs on (esp8266) architecture(s).
In file included from /home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/tools/sdk/lwip2/include/lwip/ip_addr.h:43:0,
from /home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/tools/sdk/include/user_interface.h:30,
from /home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/libraries/ESP8266WiFi/src/ESP8266WiFiSTA.h:29,
from /home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/libraries/ESP8266WiFi/src/ESP8266WiFi.h:34,
from /home/peter/Documenten/Arduino/ESPEasy/ESPEasy_R120/Source/ESPEasy/ESPEasy.ino:215:
/home/peter/Documenten/Arduino/ESPEasy/ESPEasy_R120/Source/ESPEasy/Networking.ino: In function 'void SSDP_send(byte)':
/home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/tools/sdk/lwip2/include/lwip/ip4_addr.h:199:54: error: request for member 'addr' in 'ip', which is of non-class type 'uint32_t {aka unsigned int}'
#define ip4_addr1(ipaddr) (((const u8_t*)(&(ipaddr)->addr))[0])
/home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/tools/sdk/lwip2/include/lwip/ip4_addr.h:205:38: note: in expansion of macro 'ip4_addr1'
#define ip4_addr1_16(ipaddr) ((u16_t)ip4_addr1(ipaddr))
/home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/tools/sdk/lwip2/include/arch/cc.h:87:24: note: in expansion of macro 'ip4_addr1_16'
#define IP2STR(ipaddr) ip4_addr1_16(ipaddr), \
/home/peter/Documenten/Arduino/ESPEasy/ESPEasy_R120/Source/ESPEasy/Networking.ino:531:22: note: in expansion of macro 'IP2STR'
IP2STR(&ip)
/home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/tools/sdk/lwip2/include/lwip/ip4_addr.h:200:54: error: request for member 'addr' in 'ip', which is of non-class type 'uint32_t {aka unsigned int}'
#define ip4_addr2(ipaddr) (((const u8_t*)(&(ipaddr)->addr))[1])
/home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/tools/sdk/lwip2/include/lwip/ip4_addr.h:206:38: note: in expansion of macro 'ip4_addr2'
#define ip4_addr2_16(ipaddr) ((u16_t)ip4_addr2(ipaddr))
/home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/tools/sdk/lwip2/include/arch/cc.h:88:5: note: in expansion of macro 'ip4_addr2_16'
ip4_addr2_16(ipaddr), \
IP2STR(&ip)
/home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/tools/sdk/lwip2/include/lwip/ip4_addr.h:201:54: error: request for member 'addr' in 'ip', which is of non-class type 'uint32_t {aka unsigned int}'
#define ip4_addr3(ipaddr) (((const u8_t*)(&(ipaddr)->addr))[2])
/home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/tools/sdk/lwip2/include/lwip/ip4_addr.h:207:38: note: in expansion of macro 'ip4_addr3'
#define ip4_addr3_16(ipaddr) ((u16_t)ip4_addr3(ipaddr))
/home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/tools/sdk/lwip2/include/arch/cc.h:89:5: note: in expansion of macro 'ip4_addr3_16'
ip4_addr3_16(ipaddr), \
IP2STR(&ip)
/home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/tools/sdk/lwip2/include/lwip/ip4_addr.h:202:54: error: request for member 'addr' in 'ip', which is of non-class type 'uint32_t {aka unsigned int}'
#define ip4_addr4(ipaddr) (((const u8_t*)(&(ipaddr)->addr))[3])
/home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/tools/sdk/lwip2/include/lwip/ip4_addr.h:208:38: note: in expansion of macro 'ip4_addr4'
#define ip4_addr4_16(ipaddr) ((u16_t)ip4_addr4(ipaddr))
/home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/tools/sdk/lwip2/include/arch/cc.h:90:5: note: in expansion of macro 'ip4_addr4_16'
IP2STR(&ip)
/home/peter/Documenten/Arduino/ESPEasy/ESPEasy_R120/Source/ESPEasy/_C002.ino: In function 'boolean CPlugin_002(byte, EventStruct*, String&)':
_C002:45:9: error: 'StaticJsonBuffer' was not declared in this scope
StaticJsonBuffer<512> jsonBuffer;
_C002:45:31: error: 'jsonBuffer' was not declared in this scope
_C002:48:18: error: 'class ArduinoJson660_0_0::JsonObject' has no member named 'success'
if (root.success())
_C002:121:9: error: 'StaticJsonBuffer' was not declared in this scope
StaticJsonBuffer<200> jsonBuffer;
_C002:121:31: error: 'jsonBuffer' was not declared in this scope
_C002:198:14: error: 'class ArduinoJson660_0_0::JsonObject' has no member named 'printTo'
root.printTo(json, sizeof(json));
/home/peter/Documenten/Arduino/ESPEasy/ESPEasy_R120/Source/ESPEasy/_P016_IR.ino: At global scope:
_P016_IR:6:1: error: 'IRrecv' does not name a type
IRrecv *irReceiver;
_P016_IR:7:1: error: 'decode_results' does not name a type
decode_results results;
/home/peter/Documenten/Arduino/ESPEasy/ESPEasy_R120/Source/ESPEasy/_P016_IR.ino: In function 'boolean Plugin_016(byte, EventStruct*, String&)':
_P016_IR:51:13: error: 'irReceiver' was not declared in this scope
if (irReceiver == 0 && irPin != -1)
_P016_IR:54:27: error: expected type-specifier before 'IRrecv'
irReceiver= new IRrecv(irPin);
_P016_IR:54:27: error: expected ';' before 'IRrecv'
_P016_IR:57:13: error: 'irReceiver' was not declared in this scope
if (irReceiver != 0 && irPin == -1)
_P016_IR:61:18: error: type '<type error>' argument given to 'delete', expected pointer
delete irReceiver;
_P016_IR:70:13: error: 'irReceiver' was not declared in this scope
if (irReceiver->decode(&results))
_P016_IR:70:33: error: 'results' was not declared in this scope
Multiple libraries were found for "PubSubClient.h"
Used: /home/peter/Documenten/Arduino/Sketches/libraries/pubsubclient
Not used: /home/peter/Documenten/Arduino/Sketches/libraries/PubSubClient
Multiple libraries were found for "Servo.h"
Used: /home/peter/.arduino15/packages/esp8266/hardware/esp8266/2.4.2/libraries/Servo
Not used: /home/peter/Documenten/Arduino/Sketches/libraries/Servo
Not used: /home/peter/Documenten/Arduino/arduino-1.8.7/libraries/Servo
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
