OLED on
OLED on
Hi all,
I used the Nodemcu with espeasy (latest release/NodeMCU) with a small framed OLED display SH1106.
ESPeasy shows variables and genrell text, what I want. no problem.
But via remote (f.e. http or mqtt), nothing happens.
My log shows:
"WD : Uptime 2 ConnectFailures 0 FreeMem 13096"
What is the problem ?
My system info table:
Firmware
Build:⋄ 20103 - Mega
Libraries:⋄ ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support
GIT version:⋄ mega-20181231
Plugins:⋄ 46 [Normal]
Build Md5: 26bae7842d90adf4b1f96821e528ba4
Md5 check: passed.
Build time:⋄ Dec 31 2018 03:12:49
Binary filename:⋄ ESP_Easy_mega-20181231_normal_ESP8266_4096.bin
System Status
Syslog Log Level: None
Serial Log Level: None
Web Log Level: Info
ESP board
ESP Chip ID: 1596110 (0x185ACE)
ESP Chip Freq: 80 MHz
ESP Board Name: PLATFORMIO_ESP12E
My log shows:
Firmware
Md5 check: passed.
System Status
Web Log Level: Info
ESP board
Re: OLED on
What commands are you using exactly?
Please tell us how you invoke them.
Re: OLED on
nobody any ideas ?
What about import mqtt and set variables for showing ?
Re: OLED on
If you try the command through the "tools" page? Not working either?
Re: OLED on
Syntax error?
http://<espeasyip>/control?cmd=<command>
Single slash after IP !
Re: OLED on
Good catch... But also MQTT is not working? We really need more info on exact syntax being used here...Domosapiens wrote: ↑05 Jan 2019, 20:26 Syntax error?
Re: OLED on
sorry, my mistake. I used this string: http://<espeasyip>/control?cmd=oled.....
without double "//"!
That istn't the error.
here is my actual log:
169412144: WD : Uptime 2824 ConnectFailures 4 FreeMem 12904
169430480: HTTP: oledcmd,clear
169442143: WD : Uptime 2824 ConnectFailures 4 FreeMem 12904
169449685: HTTP: oled,1,1,text
169457173: EVENT: Clock#Time=Sun,18:53
169472143: WD : Uptime 2825 ConnectFailures 4 FreeMem 12888
After sending the commands , nothing happens on the screen.
AND what about the "ConnectFailures" ?
Re: OLED on
The connect failures are probably from the beginning of the start, see that those are "only" 4 in 2800+ minutes.
But which plugin are you using, framed or "basic"? Because the command for the framed is OLEDFRAMEDCMD.
I know we're lacking in the area of documentation .. I'm hunting paid job assignments in order to get time to spend on this. It's not that I don't think it's awesome we have 80+ patrons and getting Ko-Fi 4-5 times a week but we're in desperate need of support to be able to dedicated all our time on this.
Re: OLED on
correction: I use the normal display ssd1306.
Have I installed the plugin ?
or is it automatically installed?
Re: OLED on
The commands oled and oledcmd give no error back.
but also no output on display
Re: OLED on
Yes it's either-or, if you find it in the drop down menu and you have it all set up and working then you have it
OLEDFRAMEDCMD,Off
As an example...
But you want to update the lines? With costum text etc?
OLEDFRAMEDCMD,Off
As an example...
Re: OLED on
You should probably use the other OLED plugin since that one you can change the text via commands.
Re: OLED on
If I insert the text into the device configuration, it works and display the text.
That is, what I want: insert text to display (for status from my other system (iobroker))
Re: OLED on
Not possible with the framed OLED plugin (yet). That is why we have the old basic plugin left in the list. Sorry for the confusion.
What info are we talking about, float/integers or strings?
Re: OLED on
I want to insert strings, f.e. "Door open", "Door close"
Re: OLED on
and how can I use the other plugin ?
Re: OLED on
Ok, not possible no (not yet). Either use the old plugin or insert it by the use of values.
Door: 1
Door: 0
For open/closed. These values can be assigned in multiple ways. Strings are not yet possible.
Door: 1
Door: 0
Re: OLED on
Delete the current one (in the settings) and add the other.
Re: OLED on
But, did you use the framed OLED plugin or not?
Re: OLED on
I am not realy sure. here I inserted a picture.
- IMG_1260.JPG (580.41 KiB) Viewed 11940 times
Re: OLED on
I'll try now the OLED SSD1306 plugin.
I can now insert text on the first line, but it works not for 2. /3. and so on.
Is that not possible? I'll try: OLED,1,1,test
Re: OLED on
That picture slows that it's the framed OLED plugin (the status bar on the top of the display). But you would clearly see which plugin your using in the settings page...
PS. To change the text on other lines, change the command to OLED,2,1,TEXT etc...
Re: OLED on
Attach my actual configuration.
But didn't work. ESPEasy inserted allways my text into the first line.
and what about my variables configuration? I see only "Tuer1: %Z1%"
- Anmerkung 2019-01-07 080713.jpg (73.89 KiB) Viewed 11889 times
- Anmerkung 2019-01-07 080628.jpg (75.65 KiB) Viewed 11889 times
Users browsing this forum: No registered users and 92 guests
