Help needed, i'm unable to ring a buzzer when a MQTT message is recieved by espeasy.
Ringing a buzzer with url and startup is working fine. Any clue or working examples? I looked in the wiki already
MQTT Import and buzzer not working
domotica fan, using Espeasy, esphome, tasmota
Re: MQTT Import and buzzer not working
Post to topic "cmdMQTT" since that is what you have set as topic for the MQTT importer plugin.
I did also: /ESP_Easy3/cmdMQTT (value off 1) no succes. Do you have a complete example? Wiki isn't very helpfull
Instead of /ESP_Easy3/cmdMQTT try cmdMQTT without any slash and no system name. You're subscribing to only that single topic level. If you want to listen to the full topic you need to add that to the MQTT import plugin settings.
Thanks that is working!
Users browsing this forum: No registered users and 44 guests
