Could you please clarify if I'm wrong or is it Rules malfunction?
I'm going to provide hysteresis to the heating system, so trying the next:
if [sniff2#1floortemp]<[targetT#1floor]-0.3 and [sniff#1floor]=1
mcpgpio,11,1
TaskValueSet 3,1,1
sniff2#1floortemp and targetT#1floor are MQTT-import devices.
It seems that "-0.3" is ignored.
Is that normal behavior?
GIT version: mega-20190108
TIA
Alexander
Maths in Rules malfunction?
Rgds,
Alexander
Alexander
Re: Maths in Rules malfunction?
This is normal yes, for the if statement you cannot add maths. Use the formula within the task settings. For targetT#1floor you just add %value%-0.3 to the formula line.
The being said, you can use math in rules but not in the if statement.
Thanks for reply.
Well, in my case formula won't help since the whole piece of rule is:
mcpgpio,11,1
TaskValueSet 3,1,1
if [sniff2#1floortemp]>[targetT#1floor] or [sniff#1floor]=0
mcpgpio,11,0
TaskValueSet 3,1,0
As you can see, the next lines should use "clean" targetT#1floor, so the hysteresis is 0.5 degree.
Is there any other best practice except creating of dedicated dummy device?
TIA
Alexander
mcpgpio,11,1
TaskValueSet 3,1,1
mcpgpio,11,0
TaskValueSet 3,1,0
TIA
Alexander
Rgds,
Alexander
Alexander
Let,1,[targetT#1floor]-0.3
If [sniff2#1floortemp]<[VAR#1] and [sniff#1floor]=1
mcpgpio,11,1
TaskValueSet 3,1,1
EndIf
Perfect! Thanks a lot.
I haven't heard about this function before.
Please consider adding it to the Wiki: https://www.letscontrolit.com/wiki/inde ... rial_Rules
TIA
Alexander
TIA
Alexander
Rgds,
Alexander
Alexander
That wiki is in the process of being replaced by "read the docs". It's not fully completed though.
https://espeasy.readthedocs.io/en/latest/
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 36 guests
