I trying to use MQTT import with ESPEasy Mega 2.0. The MQTT broker is a Home Assistant, and I'm able to send MQTT messages to GPIO ports. But I can't seem to receive any MQTT messages on the MQTT Import module.
This is the setup on the import-module and the message I'm trying to publish from MQTT.fx:
Problems with MQTT Import
- MQTT Import.png (63.19 KiB) Viewed 2956 times
- mqtt.fx.png (28.67 KiB) Viewed 2956 times
Re: Problems with MQTT Import
MQTT import is it's own MQTT client. That means that the entire topic you have in the settings is the topic you send your values you want to import.
In your case: publish to mqttcmd
Thank you for answer. I tried the setting like this, and it still doesn't change the value. Does import MQTT use the same broker as the the ESP?
- mqtt2.png (38.82 KiB) Viewed 2930 times
I looked at your settings once more. You have set the topic to temp. No slashes or anything.
It worked like a charm Thank you very much
Great!
Users browsing this forum: No registered users and 84 guests
