Problems with event call in rules ?
Lenif
#1 Post by Lenif » 08 Mar 2019, 08:14
I just update my SonOFF DUAL because regularly, they disconnected from the wifi and I had to reboot via the power supply (because difficult to access).
So I installed the version of March 5th. I'm having trouble with the Rules in this version. Everything works fine except the event call from button event.
My rules:
on System#Boot do
  gpio,12,0 // Relay 1
  gpio,5,0  // Relay 2
on Bouton#Bouton do  // normal switch (not push)
  DoAction=25
on DoAction do
  if [RelaisUP#RelaisUP]=1 or [RelaisDOWN#RelaisDOWN]=1 //2 switch on the gpio to get output state
    event DoStop
    event StartVolet=%eventvalue%
on StartVolet do
  if [Volet#VersLeBas]=1  // Dummy(4-1) last up or down
    event DoUp=%eventvalue%
    event DoDown=%eventvalue%
On DoStop do
   gpio,12,0
   gpio,5,0
   timerset,2,0
On DoUp do
  gpio,12,0
  gpio,5,1
  TaskValueSetAndRun 4,1,0 // Last action is going up
  timerset,2,%eventvalue%
On DoDown do
  gpio,5,0
  gpio,12,1
  TaskValueSetAndRun 4,1,1 // Last action is going down
on Rules#Timer=2 do
 gpio,12,0
 gpio,5,0
Maybe there is a simple way to do it but it works on build mega-20181101.
On the build from 20180305, when I use the button, my sonoff reboot. :(
The event DoAction, DoStop, DoUP and DoDown can be called via http without any problems, all is working good but via button event, I get a reboot. :(
I don't understand what's happening.
Thanks for your help and any suggestion.
Lenif,
Belgium
kimot
Re: Problems with event call in rules ?
#2 Post by kimot » 08 Mar 2019, 09:56
What is:
DoAction=25
And I am not sure, if your event call method is correct:
Calling event with value assigned.
Lenif
#3 Post by Lenif » 08 Mar 2019, 16:32
Hello, off course, it's "event DoAction=xx", just mistyping
Lenif
#4 Post by Lenif » 08 Mar 2019, 16:51
I notice today that the icon that represents my shutters is not correct today. I added an additional state that I activate in the system#boot event so I can easily see on my Jeedom interface if the sonoff has rebooted.
In the day one of the sonoff reboot while no command was sent.
schnurzel59
#5 Post by schnurzel59 » 15 Mar 2019, 14:25
Hi Lenif,
You say:
I think the not working version is these: 20190305. (Not 2018) ?
Why do not you stay with version 20181101?
If everything is going well, then you should be happy. What has improved so important in the version 20191101, what you really need?
It is unfortunately always trying to insert something new into the ESPEasy. It would be better to eliminate the long-known fundamental problems.
My tip: Stay with a working version.
Here is my variant of a shutter control. I can get to a certain position, no matter what the old position was.
Event, DoAction = 7 means drive to position 7.
When booting, the desired standard position is approached.
Like "ShutterReset". Got to Top or Bottom. Relay 1 --- gpio12 --- down Relay 2 --- gpio5 ----- up.
Would be interesting to know if it works. For me there was no problem with any mega-version. Unfortunately, the
ESP8266-MCU often reboots. This problem is well known, but still not eliminated.
I manage with it 3 shutters. "Event,GoTo=12,5,17" means: Left pos. 12, middle pos. 5, right pos. 17
I hope, when adapting to your devices no errors have arisen. But you see that yourself.
Since you have set up a switch in the lower part of your devices, "LongPulse" should work. Without a switch at this point, a longpulse only turns on and not off.
on System#Boot do
       gpio,12,0 // Relay 1  down off
       gpio,5,0  // Relay 2  up   off
       event ShutterReset
on ShutterReset do
	Longpulse,5,1,25			// or Longpulse,12,1,25
	If [Volet#VersLeBas]>10  		// Old Position from  0=up to 25=down
	gpio,12,0
	Longpulse,5,1,25			// Then up to the End
	TaskValueSet,4,1,0 			// Now in Pos.0  upper position
	gpio,5,0
	Longpulse,12,1,25			// Then down to the End
	TaskValueSet,4,1,25 			// Now in Pos.25  lower position
On DoStop do
      gpio,12,0
      gpio,5,0
on DoAction do					// Event,DoAction=7. That means: Go to position 7. Position 0 is up, position 25 is down.
  let,1,%eventvalue%       			// %var1%
  if [Volet#VersLeBas]>%eventvalue%      	// Old position bigger than new.
    let,1,[Volet#VersLeBas]-%eventvalue%	// Diff. write in var1
    gpio,12,0
    Longpulse,5,$var1% 				// (Diff-Time) up
  if [Volet#VersLeBas]<%eventvalue%		// Old position smaller than new.
    let,1,%eventvalue%-[Volet#VersLeBas]	// Diff. write in var1
    gpio,5,0
    Longpulse,12,$var1% 			// (Diff-Time) down
  TaskValueSet 4,1,%eventvalue%		 	// New position
Martin
Greetings Martin
pe1ago
#6 Post by pe1ago » 18 Aug 2019, 21:00
Hello Martin,
I am little new to this.
I think this code is what i can adapt and use for my blinds, but:
a. can you tell me what device type you use in esp-easy
b. can you tell me what device type you use in domoticz
With domoticz blinds and esp-easy, Output - Domoticz MQTT Helper it is not working for me.
Thanks in advance,
Regards Hans
