(solved) upload rule remote via json or any other remote script
I am wondering if it would be possible to use the flash process remote
via json
or other methodes?
Thanks T
via json
or other methodes?
Thanks T
Re: upload rule remote via json or any other remote script
You can use curl and upload a rule text file.
Sounds great
Naming of Textfile Just rules1.txt?
Yep, and make sure you have the latest and greatest version.
Hi I am struggling with the curl command
do you have an example please?
I assume it is a curl -u upload
Thanks thomas
Thanks thomas
could yo upost a template uploading rules?
It is not working for me.
Thanks T
Thanks T
could you post a template uploading rules? It is not working for me.
Try this:
1. Go to the rules tab and choose the rule set you wish to update. If it does not exist then this action will create a blank rule file in SPIFFS with the rulesX.txt naming convention. If there is already a rule file present then that is fine too.
2. Close the rules tab (exit the rules page). This is mandatory! Failure to do this will cause rules1.txt to be copied to the currently selected rules page when you use curl. {this bug caused me a lot of grief}
3. Use curl to submit the new ruleX.txt file, using this format:
curl -v -F upload=@FULL_PATH_TO_RULES\rules2.txt http://IP_ADDRESS/upload
Hi Thomas
thanks working perfect!!
Re: (solved) upload rule remote via json or any other remote script
Great! Thanks for confirming the workaround helped you out.
- schnurzel59
ThomasB do not Sleeping. ThomasB must be an Robot.
Greetings Martin
Oh God, my English is horrible.
Shhhush! That's suppose to be a secrete.ThomasB must be an Robot.
Users browsing this forum: Bing [Bot], Google [Bot] and 98 guests
