(solved) upload rule remote via json or any other remote script
riker1
#1 Post by riker1 » 09 Mar 2019, 08:38
I am wondering if it would be possible to use the flash process remote
via json
or other methodes?
Thanks T
Re: upload rule remote via json or any other remote script
#2 Post by grovkillen » 09 Mar 2019, 09:16
You can use curl and upload a rule text file.
riker1
#3 Post by riker1 » 09 Mar 2019, 09:19
Sounds great
Naming of Textfile Just rules1.txt?
#4 Post by grovkillen » 09 Mar 2019, 09:28
Yep, and make sure you have the latest and greatest version.
riker1
#5 Post by riker1 » 09 Mar 2019, 15:09
Hi I am struggling with the curl command
do you have an example please?
I assume it is a curl -u upload
Thanks thomas
riker1
#6 Post by riker1 » 27 Mar 2019, 12:56
could yo upost a template uploading rules?
It is not working for me.
Thanks T
#7 Post by ThomasB » 28 Mar 2019, 18:01
could you post a template uploading rules? It is not working for me.
Uploading rules files using curl appears to be partially broken. The main issue is that it will only work if the file to be uploaded is already named in the file system.
Try this:
1. Go to the rules tab and choose the rule set you wish to update. If it does not exist then this action will create a blank rule file in SPIFFS with the rulesX.txt naming convention. If there is already a rule file present then that is fine too.
2. Close the rules tab (exit the rules page). This is mandatory! Failure to do this will cause rules1.txt to be copied to the currently selected rules page when you use curl. {this bug caused me a lot of grief}
3. Use curl to submit the new ruleX.txt file, using this format:
curl -v -F upload=@FULL_PATH_TO_RULES\rules2.txt http://IP_ADDRESS/upload
note: Change FULL_PATH_TO_RULES\rules2.txt and IP_ADDRESS with your information.
riker1
#8 Post by riker1 » 28 Mar 2019, 18:14
Hi Thomas
thanks working perfect!!
Re: (solved) upload rule remote via json or any other remote script
#9 Post by ThomasB » 28 Mar 2019, 18:40
Great! Thanks for confirming the workaround helped you out.
schnurzel59
#10 Post by schnurzel59 » 29 Mar 2019, 00:56
ThomasB do not Sleeping. ThomasB must be an Robot.
Greetings Martin
#11 Post by ThomasB » 29 Mar 2019, 02:17
Shhhush! That's suppose to be a secrete. :)
