Sonoff Basic and latest versions of ESP firmware
Posted: 25 Mar 2019, 11:59
by ManS-H
Last week i was busy with my two Sonoff-Basic modules. I put the version ESP_Easy_mega-20190121_normal_ESP8266_1024 on it. Problems with connecting on Wifi.
Then i tried the version ESP_Easy_mega-20190315_normal_ESP8266_1M, same problems. Then i go back to a very old version, ESPEasy_R147_1024. A direct hit, everything works as normal.
The other ESP's worked with ESPEasy_R145_1024 and ESP_Easy_mega-20180625_normal_ESP8266_1024, i'm very lazy with updating firmware. So i flashed ESP_Easy_mega-20180625_normal_ESP8266_1024 on that Sonof-Basic. It works directly.
My question, is there something changed so much that older Sonoff-Basic modules not work anymore with the latest software?
Re: Sonoff Basic and latest versions of ESP firmware
Posted: 25 Mar 2019, 12:36
by grovkillen
Have you made a blank flash in-between? The settings have been refactored...
Posted: 25 Mar 2019, 16:26
by ManS-H
grovkillen wrote: ↑25 Mar 2019, 12:36
Yep, first i cleaned up with blank_1MB
I tried it again, first i used blank_1MB, then ESP_Easy_mega-20190315_normal_ESP8266_1M, I controlled the process with ESPplorer.
I see on my telephone ESP_Easy-0, connected, no internet.
I see the same with ESP_Easy_mega-20190121_normal_ESP8266_1024
When i use ESPlorer and fill all the fields by hand it works in both situations.
Then i tried ESP_Easy_mega-20181201_normal_ESP8266_1024, no problem. Works as a charme.
And yes, before changed the firmware i used blank_1MB
After this i want for 100% sure. i used blank_1MB, the i flashed ESP_Easy_mega-20190315_normal_ESP8266_1M. I see ESP_Easy_0, connected, no internet.
With ESPlorer it was possible too fill the fields and working with this build.
Tell me what's the problem, i don't see it.
Posted: 25 Mar 2019, 16:33
Can you give a very short summary of what is working and what isn't?
As I read it, you could make it to work with the last build?
But what did you do differently compared to the first attempt?
And what is this ESPlorer?
Posted: 25 Mar 2019, 16:48
by ManS-H
TD-er wrote: ↑25 Mar 2019, 16:33
I can made it works with the ESPlorer, but not as normal with 192.168.4.1
When i flash ESP_Easy_mega-20190121_normal_ESP8266_1024 and ESP_Easy_mega-20190315_normal_ESP8266_1M i see ESP_Easy_0, connected, no internet
https://www.esp8266.com/viewtopic.php?f=22&t=882
Posted: 26 Mar 2019, 19:50
by kimot
My Sonoff Basic:
- 2019-03-26-194435_1920x1080_scrot.png (101.79 KiB) Viewed 5594 times
I think message " ESP_Easy_0, connected, no internet" is correct.
ESPeasy is in AP mode ( and without internet connection of course )
You must connect to it ( 192.168.4.1 ) and set your wifi network SSID and password.
Posted: 26 Mar 2019, 20:58
by ManS-H
kimot wrote: ↑26 Mar 2019, 19:50
My Sonoff Basic:
Yes, you have right, that the normal situation. But in my case the screen with the access points doesn't pop up. But when i use the file of 28-06-2018 no problem at all. Even with the builds 120 and 148 works correct.
I used my cellphone for it. Now i tried it with my tablet and it works. Strange, but working.
