Rules - i have problem.
kpisiek
#1 Post by kpisiek » 27 Mar 2019, 20:08
I have a problem with rules. For the device that I have is a strip with 3 sockets but 1 button.
Let's assume the version: I enable socket 1 through the app, the remaining 2.3 are disabled.
When I press the button on the slat. Slot 1 will turn off, the rest will turn on.
I would like to create a rule that will send to IDX and allow all three to be included in the button.
And that when you attach the slat, it also sent home information about the attached socket.
Actual rule:
On System#Boot do
 gpio,3,0
On WIFI#Connected do
SendToHTTP 10.10.10.254,8080,/json.htm?type=command&param=switchlight&idx=18&switchcmd=Off ### correct?
SendToHTTP 10.10.10.254,8080,/json.htm?type=command&param=switchlight&idx=19&switchcmd=Off ### correct?
SendToHTTP 10.10.10.254,8080,/json.htm?type=command&param=switchlight&idx=20&switchcmd=Off ### correct?
on Button1#state do
  if [Relay1#state]=0 or [Relay2#state]=0 or [Relay3#state]=0
    gpio,5,1
    gpio,4,1
    gpio,13,1
    gpio,5,0
    gpio,4,0
    gpio,13,0
on Relay1#state do
  if [Relay1#state]=0
    gpio,1,1
    gpio,1,0
on Relay2#state do
  if [Relay3#state]=0
    gpio,1,1
    gpio,1,0
on Relay3#state do
  if [Relay3#state]=0
    gpio,1,1
    gpio,1,0
GPIO-1 is LED
GPIO 5,4,13 Relay
Electrican in coal mine.
dampa
Re: Rules - i have problem.
#2 Post by dampa » 31 Mar 2019, 19:47
take a look at this thread viewtopic.php?f=4&t=6586 it may help you debug and give you insight to your problem
