PWM dimming, delay, decreasing??
bastibasti
#1 Post by bastibasti » 02 Apr 2019, 22:53
I'm trying to convert an old avr dimmer to esp8266 with espeasy. So far, hardware works as expected... However, it seems like, when setting the pwm, for example
pwm=12,1024,1000 -> ok nice and smooth
pwm=12,100,1000 -> it goes to 0 and then starts to increase to 100, instead of decreasing from 1024
if you set
pwm=12,0,1000 -> immediately off
is this intentionally or a bug??
Re: PWM dimming, delay, decreasing??
#2 Post by ThomasB » 03 Apr 2019, 05:09
I reviewed _P001_Switch.ino to see if there is an explanation. As written, PWM (with optional duration function) is configured to "increase" the PWM value (e.g., brighten effect). It does not offer a traditional fade. But it will wrap around to a lower PWM value when the new PWM value is smaller than the previous. This matches what you are seeing.
I would label it as an intentional bug. :)
bastibasti
#3 Post by bastibasti » 07 Apr 2019, 23:14
what a mess.
mega-20181028 is able to slowly dim down.
are there any notes, why the behaviour was changed?
#4 Post by ThomasB » 08 Apr 2019, 01:46
The switch plugin went through some changes a few weeks ago. There was some discussion on it doing too much. Then it was reverted after things broke. I'm surprised you see it working differently than before.
bastibasti
#5 Post by bastibasti » 12 Apr 2019, 21:07
also, while I'm complaining like an old woman.... an option to set the pwm frequency would be great. like pwmfreq=100 for 100hz
Domosapiens
#6 Post by Domosapiens » 13 Apr 2019, 00:46
PWM,<GPIO>,<duty>,<duration>,<frequency>
https://espeasy.readthedocs.io/en/lates ... hlight=pwm
Rampler
#7 Post by Rampler » 13 Apr 2019, 17:36
This is a known bug !!
Use a version with Core 2.4.1, all is fine ...
I use ESPEasy_mega-20180506 and PWM is working.
bastibasti
#8 Post by bastibasti » 13 Apr 2019, 23:05
Rampler wrote: 13 Apr 2019, 17:36 This is a known bug !!
No it isn't.... dimming down doesnt work on the 20190413 core241 i just loaded
bastibasti
#9 Post by bastibasti » 15 Apr 2019, 12:36
oh,
and I want to add:
/control?cmd=pwm,2,512,7000,500
-> I cannot find any release, where the pwmfreq is set to 500 either
its broken.
Rampler
#10 Post by Rampler » 20 Apr 2019, 15:25
bastibasti wrote: 13 Apr 2019, 23:05
As a said, try ESPEasy_mega-20180506 and all is fine ..
bastibasti
#11 Post by bastibasti » 23 Apr 2019, 09:29
I decided to go a different route. I'm currently making a wemos d1 shield with an avr that handles the pwm. (the easyesp also cannot simultaneously dim)
jbishop129
#12 Post by jbishop129 » 10 Jul 2019, 21:13
I can confirm this is still an issue. I can fade up just fine, but cannot fade down. I can also confirm that loading the much older 2018-05-06 version, fading down works just fine. What's the deal with getting this fixed, since this seems to be a regression from over a year ago?
fra290
#13 Post by fra290 » 19 Jul 2019, 16:01
bastibasti wrote: 02 Apr 2019, 22:53
... So far, hardware works as expected...
I'm interested to have the Hardware project, can you share?
MArco
bastibasti
#14 Post by bastibasti » 29 Jul 2019, 14:50
... so far still making changes and adjusting. might need a little change in hardware if i cannot adjust the speed correctly. I will reply to you later
#15 Post by TD-er » 04 Aug 2019, 15:35
This issue was caused by the pin state monitor which has been changed a while ago.
This tried to store the current PWM value in a parameter of only a few bits.
I just created a fix for this and it will be merged later today (and thus included in tomorrow's build)
Users browsing this forum: No registered users and 101 guests
