Energy Meter HLW8012 Breakout Board voltage issue
Hi to all,
Recently I bought HLW8012 Breakout Board for using 8266 (mega-20190416). As I attach picture Voltage show only 2v value. The board connected to the city electricity so it must be show at least 220 v. Is there any idea about that issue. Here is the settings and board. https://www.aliexpress.com/item/Energy- ... 4c4dGaYTFy
- hlw.jpg (55.18 KiB) Viewed 6399 times
- 2.png (57.22 KiB) Viewed 6399 times
- 1.png (35.85 KiB) Viewed 6399 times
Re: Energy Meter HLW8012 Breakout Board voltage issue
1. Does ESPeasy read current and power correctly?
2. Do you need to set up the GPIO pins as input/output under the "Hardware" tab in the GUI?
3. Also try setting "pre defind pin settings" in the device to "SonOff POW (R1)"
4. Calibration? https://espeasy.readthedocs.io/en/lates ... /P076.html
Ray
Ray
What do you suggest about state of GPIO's? (input,default,output low,output high)rayE wrote: ↑21 Apr 2019, 02:22 Hi,
Ray
GPIO → SEL:
GPIO ← CF1:
GPIO ← CF:
You did not answer point 1+4? Here is my setup using Mega 20190202. If this still does not work TRIPLE check the connections from breakout PCB to your esp8266, are they connected to the right pins?
- Devices.jpg (153.56 KiB) Viewed 6330 times
- Hardware.jpg (140.7 KiB) Viewed 6330 times
Thanks for the responce, I use a 18 watt twisted bulb to test the board, so here is the picture and answer of your questions;rayE wrote: ↑21 Apr 2019, 02:22 Hi,
Ray
1. Does ESPeasy read current and power correctly? >No, not read correctly
2. Do you need to set up the GPIO pins as input/output under the "Hardware" tab in the GUI? > Yes, I test with all possibilities and left them default
3. Also try setting "pre defind pin settings" in the device to "SonOff POW (R1)" > I try it with pre defined settings but no succeed
4. Calibration? https://espeasy.readthedocs.io/en/lates ... /P076.html > I haven't calibrate yet but I think it will not a solution because values are very diffret to calibrate see board show that 5 V voltage but actually it must be around 220 V
I noticed that, when I choose pre defined setting for pow there is nothing at the page of "Show Pin state buffer".
Is not it strange? I think there is something related p076 plugin?
Try Mega 20190202 Sonoff build, this works for me then do a calibration. Below is my pin state buffer.
- pinstate.png (68.08 KiB) Viewed 6299 times
You need to calibrate the thing before ANYTHING else! Do this first before wasting time chasing your tailI haven't calibrate yet but I think it will not a solution because values are very diffret to calibrate see board show that 5 V voltage but actually it must be around 220 V
Thanks for your suggestion, yes the calibration works. But i think there is an issue about reporting the different device property (V,A,W). It always needs new calibration for new devices. Anyways your suggestion solve my big question markrayE wrote: ↑23 Apr 2019, 15:26You need to calibrate the thing before ANYTHING else! Do this first before wasting time chasing your tailI haven't calibrate yet but I think it will not a solution because values are very diffret to calibrate see board show that 5 V voltage but actually it must be around 220 V
For testing such power monitoring parts like these, you can better test with other consumers first.
A light like you showed has a very bad power factor.
It is better to first test it with no load connected (just measuring voltage) and then using some truly Ohm load like a old fashioned light bulb or a heating element.
Those have a cos phi of 1 or very close to 1.
Testing with LED lights or those you showed do introduce all kinds of unknowns since the current they draw is hardly related to the AC voltage and thus the reported current or power may be off quite a bit.
Users browsing this forum: No registered users and 38 guests
