Outgoing TCP (Telnet) connection via UART?
bastibasti
#1 Post by bastibasti » 23 Apr 2019, 09:32
is there any way to establish an outgoing TCP (telnet) connection to another espeasy node via serial command??
kimot
Re: Outgoing TCP (Telnet) connection via UART?
#2 Post by kimot » 23 Apr 2019, 18:55
I do not exactly know what you mean (telnet ).
But you can send event through serial line and with rules send UDP command to other ESPEASY.
bastibasti
#3 Post by bastibasti » 23 Apr 2019, 20:03
ESP1: Connected to a microcontroller via UART. I can send a command to the microcontroller from the PC using the serial server in easyesp
ESP2: Connected to a microcontroller via UART. Howto send something to the microcontroller, connected to ESP1??
bastibasti
#4 Post by bastibasti » 23 Apr 2019, 22:52
basically, what I'm looking for is a sendToTCP command, so I can send a text string from one uart to another.
SendToUDP cannot do it, since the serial server only reacts to tcp connections...
bastibasti
#5 Post by bastibasti » 24 Apr 2019, 09:08
so, temporarily I solved this by using
sendtohttp,192.168.1.10,80,/control?cmd=serialsend%20COMMAND_FOR_EXTERNAL_AVR
