is there any way to establish an outgoing TCP (telnet) connection to another espeasy node via serial command??
Outgoing TCP (Telnet) connection via UART?
Re: Outgoing TCP (Telnet) connection via UART?
I do not exactly know what you mean (telnet ).
But you can send event through serial line and with rules send UDP command to other ESPEASY.
ESP1: Connected to a microcontroller via UART. I can send a command to the microcontroller from the PC using the serial server in easyesp
ESP2: Connected to a microcontroller via UART. Howto send something to the microcontroller, connected to ESP1??
basically, what I'm looking for is a sendToTCP command, so I can send a text string from one uart to another.
SendToUDP cannot do it, since the serial server only reacts to tcp connections...
so, temporarily I solved this by using
sendtohttp,192.168.1.10,80,/control?cmd=serialsend%20COMMAND_FOR_EXTERNAL_AVR
