Hi, I tried googling but couldn't find any reference to this problem
Using R120
I am using the syslog option to send my data to a syslog server
I have a BME280 that is collecting temperature, humidity, and pressure
I have calibrated the sensor and I have e.g.
Formula Temperature %value%-0.3
The adjusted values are reflected in the Devices tab, but if I go to Tools, Log, the numbers are being sent without adjustment
Any tips?
Syslog ignores formulas
Re: Syslog ignores formulas
R120 is a bit old, so there is a chance it is not capable of what you want to do. I suggest you try a recent Mega release.
Thanks Thomas. While the R120 is very stable on my device, I am struggling to get the Mega configs to work.
I have a 4G generic ESP8266
However I am getting time outs when trying to connect to it with the latest Mega, it says: " Low memory. Cannot display webpage "
I have tried several bins.
Any advice on which version / bin to use?
Use the normal build. And size should be matching your units memory.
All working now inc. atom builds. Thanks to all
Users browsing this forum: Ahrefs [Bot] and 103 guests
