Hello all,
I use an ESP 8266(E12) with firmware mega-20190409.
An Oled Display (SH1106 Framed) is connected via I2C Bus.
I have to display a value of a sensor.
On SSD1306 Displays I do it that way:
wget -O /dev/null -q http://192.168.100.50/control?cmd=OLED,4,1,"FOLIE LEER"
I know, it is not supposed to work that way with SH1106 / 1306 Framed.
I thought, it may be a good idea to try it that way:
Applying a Dummy Device called " Ext_Wert " with the values
"Rolle1 and Rolle2" (1 decimal). Then insert the variable [Ext_Wert#Rolle1]
and [Ext_Wert#Rolle2] in Line 1 (and 2) of the display device page.
Well up to that Point, it works fine. However, you may guess already,
it displays " 0.0 ", because the variable isn't filled yet.
My Question is:
How to manipulate the variable eg. with a terminal-command or via IO/Broker ?
I'm a bit desperated meanwhile, so any help is appriciated!
Greetings
Steve
How to remote manipulate dummy device value?
- schnurzel59
Re: How to remote manipulate dummy device value?
Hello Steve,
In a Browser:
X is the Devicenumber.(1 to 12)
YYY,Y is the new Value.
Greetings
Martin
In a Browser:
http://192.168.100.50/control?cmd=taskvalueset,X,1,YYY.Y
http://192.168.100.50/control?cmd=taskvalueset,X,2,YYY.Y
Greetings
Martin
Greetings Martin
Ohh Jesus...
Thank you. I`ll test it immediately!
Steve
You made my dayschnurzel59 wrote: ↑02 May 2019, 11:45 Hello Steve,
In a Browser:X is the Devicenumber.(1 to 12)Code: Select all
http://192.168.100.50/control?cmd=taskvalueset,X,1,YYY.Y http://192.168.100.50/control?cmd=taskvalueset,X,2,YYY.Y
Greetings
Martin
Steve
- schnurzel59
I am very happy that you are happy.
Greetings Martin
Users browsing this forum: No registered users and 49 guests
