I'm using a Keraky Acces point flashed with openwrt firmware on it.
The wifi works very wel in my house.
When i try to connect the ESP8266 with espeasy on it, it can't connect to that wifi.
SSID is open, iv'e try to create a SSID with WPA 2 but i have the same issue.
Wifi is detected by esp easy but never connect.
I've set a second ap as fall back wich is a Fritzbox, and it always connect on it.
Does anyone has same kind of issues ?
Any idea if it's espeasy firmware related or something wrong in the ap setup ?
Thx
Wifi compatibility issue
Re: Wifi compatibility issue
Yeah, I am facing same issue. Its not getting connected
What channel is it using?
Does it enforce some strict connectivity rules, like only 40 MHz channel bandwidth, only 802.11N etc?
Users browsing this forum: No registered users and 25 guests
