wifi signal strength
is it possible to get wifi signal strength in esp easy.
Re: wifi signal strength. SOLVED?!
change to least version (R81), there it is shown on the main page.
SOLVED, i guess.
SOLVED, i guess.
Is there a way to send wifi signal level of the device to domoticz and check the signal level of the device on domoticz app?
definitely it is.
You can setup a task for "System info" and choose "RSSI".
It is a value like any sensor value then and can be send to the Controller.
definitely it is.
Hi Shardan,
Thank you so much.
Thank you so much.
About RSSI strenght: is it actually enabled in the framed oled display ?
thanx & regards.
paolo
thanx & regards.
paolo
- Inked20170531_135042_LI.jpg (1.34 MiB) Viewed 7032 times
Users browsing this forum: No registered users and 114 guests
