It is a basic question but I went through the forum and I didn't find any answer. The keywords are maybe too simple.
I would like to use the sonoff S20 in my bedroom, so I would like ALL the lights(circle green, blue) to be switched off, but I need the sonoff to remain "active"( button, switch) because I have a light connected to it.
Is there a way to switch off all the lights without changing the behaviour?
Gilles
SONOFF S20 : Disable the blue and circle green lights
Re: SONOFF S20 : Disable the blue and circle green lights
GPIO 13
When I set the GPIO13 to 0, the blue light is switched off, but the green circle is switched on. I need both to be switched off to sleep .
Is there a way to switch off the green one and the blue one?
Nevertheless, I need the sonoff internal switch to be up because I have a lamp connected to the sonoff.
The green LED is physically connected together with the relay to GPIO12. So remove the LED or put something black over it.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 102 guests
