Data being sent to ThingSpeak not in regular intervals
I am trying to sent the data from 4 different sensors (7 different values) to ThingSpeak every 30 seconds. Sensors are set to get the data each 30 seconds (or more frequent). Messaging frequency in Advanced settings is set to 30 seconds. Nevertheless datat from some sensors are received by Thingspeak more frequently than from the others - check the channel:
https://thingspeak.com/channels/813426
Any idea what could be causing this behaviour (and more important how to fix it?)
Thank you
Thank you
Re: Data being sent to ThingSpeak not in regular intervals
I suggest you don't tinker with the advanced settings for messages. Instead use rules to publish the values.
The following will write all 8 fields to a public/private channel. Replace write API key and vars with your stuff. Trigger the send from a timer.
Love it! IOT Bees
Ray
SendToHTTP api.thingspeak.com,80,/update?key=YourWriteAPIkey&field1=[HLW_Accu#V]&field2=[HLW_Accu#A]&field3=[HLW_Accu#W]&field4=[S_Info#Pcount]&field5=[S_Info#WiFi]&field6=[S_Info#Load]&field7=[S_Info#Uptime]&field8=[S_Info#MQTT]
Ray
THANKS for making me a bit more clever again, rayE!
Works very well!
Works very well!
Wonderful mate, glad i could be of help.
Keep those IOT bees happy as without them the human race is SCREWED Please keep me updated on any progress. I live in the Philippines and honey is a very much liked product here as well as general cross pollination of plants provided by our furry flying friends .
Do you have a website/blog on what your doing? If not you really should as it's so important. Perhaps i can help spread your knowledge over here?
Best Regards
Ray
Best Regards
Ray
Hi Ray!
you can check here http://itrubec.cz/en - unfortunately not too many topics in English. I am currently building an IoT Beehive which is going to be placed at the roof of IBM building in Brno, Czech Republic. The data will be public. Please keep fingers crossed!
Vilem
Vilem
Good luck with the project, i for one understand the importance of what your doing
If you need any FREE assistance in this project then im an electronics design engineer with programming knowledge, give me a shout at
rayellam@yahoo.com
im semi retired and glad to assist
Ray
rayellam@yahoo.com
Ray
is there some limit on the number of GET parametres sent?
I am sending following:
and I get following (each parameter on one line):
xyz
dd1
20.1
57
23.3
48
1010
553
0
22.8
20.8
[i3
...it looks like the last parameter is not parsed properly...
SendToHTTP itrubec.cz,80,/monitor/iotbeehive.php?key=xyz&dev=dd1&f1=[DHT#TIN]&f2=[DHT#HIN]&f3=[BME#TOUT]&f4=[BME#HOUT]&f5=[BME#POUT]&f6=[Light#L]&f7=[Relay#R]&f8=[i1#T1]&f9=[i2#T2]&f=[i3#T3]
xyz
dd1
20.1
57
23.3
48
1010
553
0
22.8
20.8
[i3
Looks like there is a limit to 9 values parsed from sensors. I needed 10, so I did following workarround:
On Rules#Timer=2 do
timerSet,2,59
if [Relay#R]=0
SendToHTTP itrubec.cz,80,/monitor/iotbeehive.php?a=[DHT#TIN]&b=[DHT#HIN]&c=[BME#TOUT]&d=[BME#HOUT]&e=[BME#POUT]&f=[Light#L]&g=0&h=[HP1#hp1]&i=[HP2#hp2]&j=[Sonda#sonda]&key=xxx&dev=yyy
SendToHTTP itrubec.cz,80,/monitor/iotbeehive.php?a=[DHT#TIN]&b=[DHT#HIN]&c=[BME#TOUT]&d=[BME#HOUT]&e=[BME#POUT]&f=[Light#L]&g=1&h=[HP1#hp1]&i=[HP2#hp2]&j=[Sonda#sonda]&key=xxx&dev=yyy
From memory i think there is a limit that can be sent in one go. This can be increased, i think it's a setting in the globals file? This requires a change and recompile to the ESP source code.
Users browsing this forum: No registered users and 40 guests
