Reconfig Release code with Arduino - instructions?
JR01
#1 Post by JR01 » 30 Jul 2019, 22:17
Hi, I want to add C014 (homie) controller - using Arduino. The readme.md file in the releases points to links - this is the only one explaining how to do it - https://www.letscontrolit.com/wiki/inde ... evelopment but it seams its old - still refers to using platform.io - or am I wrong? It refers to renaming the source folder, their is not one, only src. How do I do it?
Re: Reconfig Release code with Arduino - instructions?
#2 Post by TD-er » 31 Jul 2019, 00:34
It is still by far the easiest way to build a version using PlatformIO.
For example in VS code (the editor) you can add the extension platformIO and then open the main repository directory using PlatformIO menu (the "home" page of PlatformIO is shown as soon as it is installed)
But I think we really should make a tutorial for this, since lots and lots of people keep asking how to start developing and coding, so it is apparently still a big hurdle to take at first.
If you got it working to build, you need to move the define of the controller to the right set of defines in the file define_plugin_sets.h
It should also be present in the "test" builds.
JR01
#3 Post by JR01 » 31 Jul 2019, 19:27
Thank you for the reply.
- yes please - when you get time.
vs code ?
- I use Atom, hope it will work there as well.
budman1758
#4 Post by budman1758 » 01 Aug 2019, 02:10
+1 :mrgreen: :mrgreen:
Users browsing this forum: Google [Bot] and 13 guests
