I've a soil moister probe in one ESP
Another ESP is controlling a water valve with sime timer rules.
I want to implement a extra condition to open the valve depending on the soil probe measurement from the other ESP
is it possible to simply read a value from another ESP module ?
I see we can send data to an ESP, but read ?
Thomas
rule: is it possible to use another ESP module sensor value in test condition ?
Re: rule: is it possible to use another ESP module sensor value in test condition ?
Either inter-esp-easy p2p using UDP or import values using MQTT.
Consider also the following:
esp-1 (ip address: 192.168.1.101) has the sensor and esp-2 (ip address: 192.168.1.102) controls the water valve. You can the create the following rules:
esp-1 Rule:
esp-2 Rule:
So basically you use SendToHTTP to send a command to the other esp and open the valve. I haven't tested it but I'm doing something similar.
esp-1 Rule:
on moistureSensor#value=123 do
SendToHTTP 192.168.1.102,80,/control?cmd=event,openValve
on openValve do
//code to open the valve
Users browsing this forum: Ahrefs [Bot] and 31 guests
