need some help reflashing my esp8266. The first time I tried I was successful, but managed to mess things up by setting all the io to low.
I tried reflashing, but it seems it remembers the original configuration. I tried erasing, loading blank bin but was not able to get it working similar to my first successful attempt....
So, how do I start the whole process from scratch, I initially used com4, 1024, 120 settings to flash.
ESPEASY
Re: ESPEASY
You should try a later release instead of the R120.
Re: ESPEASY
Maybe there is also the "fail safe" option present in R120, which allows to reset to factory default.
If (at boot) the ESP detects a short between RX and TX, it will issue a reset to factory default.
Users browsing this forum: No registered users and 27 guests
