Unreliable SendToHTTP?
Vilda
#1 Post by Vilda » 22 Aug 2019, 21:42
I am trying to use SendToHTTP each minute (rules code fragment below) to send actual data to my server and basically it works. The problem is there are significant gaps in the data received (see the attached picture or directly at http://itrubec.cz/monitor/iotbeehive-ibm-roof-en.php). Time to time are data missing for some minutes and then they appear again. What could be causing this?
What more - SendToHTTP to ThingSpeak stopped to work with the last update. Is someome experiencing similar behaviour? Is it caused by the latest release or is something screwed up with my rules/setup?
I am using ESP_Easy_mega-20190817_dev_ESP8266_4M.bin
On Rules#Timer=2 do
  timerSet,2,59
  if [Relay#R]=0
    SendToHTTP itrubec.cz,80,/monitor/xxx.php?a=[DHT#TIN]&b=[DHT#HIN]&c=[BME#TOUT]&d=[BME#HOUT]&e=[BME#POUT]&f=[Light#L]&g=0&h=[HP1#hp1]&i=[HP2#hp2]&j=[Sonda#sonda]&key=xxx&dev=xxx
    SendToHTTP itrubec.cz,80,/monitor/xxx.php?a=[DHT#TIN]&b=[DHT#HIN]&c=[BME#TOUT]&d=[BME#HOUT]&e=[BME#POUT]&f=[Light#L]&g=1&h=[HP1#hp1]&i=[HP2#hp2]&j=[Sonda#sonda]&key=xxx&dev=xxx
2019-08-22 monitoring gaps.png (12.3 KiB) Viewed 7752 times
Re: Unreliable SendToHTTP?
#2 Post by grovkillen » 23 Aug 2019, 05:41
Not sure, perhaps the setting of the timer after the if statement could help?
#3 Post by TD-er » 23 Aug 2019, 13:06
SendToHTTP does not wait for an acknowledgement.
The controllers can be set to wait for an acknowledgement.
Something similar was found last week regarding sending data to ThingSpeak via HTTP.
See: https://github.com/letscontrolit/ESPEas ... -522628901
Users browsing this forum: No registered users and 103 guests
