Trying to send Sauna temp to Thingspeak
jarbeni
#1 Post by jarbeni » 08 Sep 2019, 20:14
Hello!
I have a 18650 battery operated wemos D1 in an enclosure in bathroom and the ds18b20 temp sensor goes to sauna.
I am using analog input along with the temp sensor, for reading battery voltage.
Instead of reading and publishing sauna temperature to Thingspeak in a fixed interval, I would like to make the temperature determine if values are sent in a slow or fast interval.
Because, when sauna is not in use, it is about 25 degrees and something like 15 minute interval is enough.
And then when sauna is turned on to heat up, the temp sensor will soon see a rise in temperature, and after +30 degrees, the interval should change to updating every 1 minute.
After sauna is shut down, and temperature drops below 30 degrees, the update interval should be 15 minutes again.
Also, when ever possible, wemos should be sleeping.
So far, I have no luck.
I´m either locked out of the web interface because of immeadiate sleeping, or things seem to work but no values are sent to ThingsPeak.
This is my latest Rule arrangement:
on Wifi#Connected do
if [Sauna#Temperature]>30
sendToHTTP api.thingspeak.com,80,/update?key=XXXXXXXXXXXXXXX&field7=[Sauna#Temperature]
timerSet,1,16      //Set Timer 1 for the next event in 16 seconds
on Rules#Timer=1 do  //When Timer1 expires, do
sendToHTTP api.thingspeak.com,80,/update?key=XXXXXXXXXXXXXXX&field8=[akku#percentage]
timerSet,1,0
delay 10000 //lähetetään tietoa 60 sek välein
deepsleep,60 //Sauna is heating, so going for short sleep
if [Sauna#Temperature]<30
timerSet,2,16      //Set Timer 1 for the next event in 15 seconds
on Rules#Timer=2 do  //When Timer1 expires, do
timerSet,2,0
delay 20000 //delay just for fun
deepsleep,900 //sauna was cold, going for a longer sleep
Re: Trying to send Sauna temp to Thingspeak
#2 Post by grovkillen » 09 Sep 2019, 14:52
Okay, you're missing the syntax. Please study the documentation regarding how to write rules. EndIf and EndOn for example is really important to get right...
I have created a simpler ruleset for you.
    event,PublishToThingSpeak=60
    event,PublishToThingSpeak=900
on PublishToThingSpeak do
  let,1,%eventvalue%
  sendToHTTP,api.thingspeak.com,80,/update?key=XXXXXXXXXXXXXXX&field7=[Sauna#Temperature]
  timerSet,1,15
on Rules#Timer=1 do
  sendToHTTP,api.thingspeak.com,80,/update?key=XXXXXXXXXXXXXXX&field8=[akku#percentage]
  deepsleep,[VAR#1]
Let is setting an internal variable to the preferred deepsleep length (only to be used later once the timer expires). I fetch the internal variable by this syntax [VAR#1].
jarbeni
#3 Post by jarbeni » 09 Sep 2019, 17:56
You made that look like so much simpler.
I kind of understand what you did there, but I need to look at that more carefully so that I really understand how that is done.
Like you said, endif and endon were something I was unsure how to put them on my code.
That "Let" is completely a new thing for me.
Thanks very much for helping me on this!
jarbeni
#4 Post by jarbeni » 09 Sep 2019, 18:17
I tried this and it is not sending anything to Thingspeak.
I do see this on serial log:
6884 : ACT  : sendToHTTP,api.thingspeak.com,80,/update?key=(MY WRITE API KEY)&field7=25.31
6894 : Command: sendtohttp
My earlier attempts failed too, even with the simpliest way to send ANYTHING.
I start to suspect that problem is in the way espeasy sends to Thingspeak using rules.
If I just make a Thingspeak controller and set a device to send values there, it always works.
#5 Post by TD-er » 09 Sep 2019, 19:07
That's right, there is also an issue about it.
The send to http called from the rules is not waiting for an acknowledgement.
jarbeni
#6 Post by jarbeni » 09 Sep 2019, 21:58
Yes, I read about that somewhere.
But why my motion detector is working ok then?
It has the collowing code and everything works:
on Motion#Detection=1 do
SendToHTTP api.thingspeak.com,80,/update?api_key=(MY WRITE API KEY)&field1=0
delay 15000
SendToHTTP api.thingspeak.com,80,/update?api_key=(MY WRITE API KEY)&field1=1
delay 60000
delay 60000
Why does this work properly then?
I know I had differences in fimware, so I updated my Sauna Thermometer but that didn´t help.
(That 0, 1, 0, is my way to have a motion indicationg spike that starts from a recent zero value, and not from some previous value in history.)
#7 Post by TD-er » 09 Sep 2019, 22:24
Oh please do not use delay in rules and especially not delay calls over several seconds.
I really should do something about this delay command, like print it on paper and burn it.
Rules' Delay Statement Considered Harmful.
Please use timers for this and don't use delay.
The delay command does halt the entire node for the set period.
jarbeni
#8 Post by jarbeni » 09 Sep 2019, 22:41
Oh okay then.. :shock:
#9 Post by grovkillen » 10 Sep 2019, 10:44
You could try this one:
  if [VAR#16]=0
   Let,16,1
   SendToHTTP,api.thingspeak.com,80,/update?api_key=(MY WRITE API KEY)&field1=0
   TimerSet,1,15
on Rules#Timer=1 do
  SendToHTTP,api.thingspeak.com,80,/update?api_key=(MY WRITE API KEY)&field1=1
  TimerSet,2,60
on Rules#Timer=2 do
  TimerSet,3,60
on Rules#Timer=3 do
  Let,16,0
Nestitherapy
#10 Post by Nestitherapy » 19 Sep 2019, 12:49
I tried and is not sent to Thingspeak.
#11 Post by grovkillen » 19 Sep 2019, 13:16
Can you send it manually? As a test.
#12 Post by TD-er » 19 Sep 2019, 15:26
SendToHTTP and thingspeak are not working, that's a known issue.
For Thingspeak you need to wait for the response from the server and SendToHTTP does not wait for a response.
For that you really need to use the Thingspeak controller.
iron
#13 Post by iron » 20 Sep 2019, 12:22
mine works...
https://thingspeak.com/channels/33034
On Thermometer#Temperature do
SendToHTTP,api.thingspeak.com,80,/update?api_key={myAPIkey]&field1=[Thermometer#Temperature]&field2=[Thermometer#Humidity]
-D
-D
