MQTT topic
madru
MQTT topic
#1 Post by madru » 01 Nov 2019, 10:30
Morning,
I am new to ESPEasy and I try to publish to my MQTT-Broker some values via a rule
reading the documentation it should be:
Publish topic, payload
some example show
publish, top, payload
but I receive the following on the broker:
Topic = Publish, payload = topic
the log shows following:
154584 : ACT  : Publish "topic", "payload"
154595 : Command: publish
I must do something wrong but I can't figure it out......
I searched the forum but did not find an answer :(
thank you for your help
M
Re: MQTT topic
#2 Post by TD-er » 01 Nov 2019, 13:50
Could you try with this test build: https://www.dropbox.com/s/7cbfjvg5ytlqc ... 8.zip?dl=0
Please let me know if these fixes do help you with your problem.
madru
Re: MQTT topic
#3 Post by madru » 01 Nov 2019, 14:58
YEP :)
does fix the topic problem
dynamicdave
Re: MQTT topic
#4 Post by dynamicdave » 01 Nov 2019, 16:08
I've just tried again with release... ESP_Easy_mega-20191028-21-PR_2698_normal_ESP8266_4M1M.bin
I have a publish command in a rule-set to publish a 'json' string.
It would seem if the payload is just a single item, then it works.
Publish,node24/ir_detector,{"ssid":"%ssid%"}
If it's more than one item, then is fails with "Failed to parse JSON string"
Publish,node24/ir_detector,{"ssid":"%ssid%","node_number":"node%unit%"}
Hope this helps to narrow-down the issue.
Re: MQTT topic
#5 Post by TD-er » 01 Nov 2019, 17:43
Could you try wrapping the last parameter in the "other" quotes?
Publish,node24/ir_detector,'{"ssid":"%ssid%","node_number":"node%unit%"}'
dynamicdave
Re: MQTT topic
#6 Post by dynamicdave » 01 Nov 2019, 18:39
Thanks for pointing out that I should have surrounded the json string (in the Publish command) with single quote marks.
I can confirm that the json string publishes correctly in this release ( ESP_Easy_mega-20191028-21-PR_2698_normal_ESP8266_4M1M.bin ).
Users browsing this forum: Google [Bot] and 9 guests
