open-drain (open-collector) on the input: is external pull-up necessary
PetrJakes
#1 Post by PetrJakes » 09 Nov 2019, 02:24
Trying to monitor Zenner water meter EDC communication module
Module parameters:
  • Output type: N-channel Open-Drain (equivalent to an open collector)
  • Max output voltage: 24 V DC
  • Max Output current: 50 mA
  • Pulse length: >= 50 ms
  • Output resistance: 110 Ω
  • Output capacity: 1 nF
To connect open collector to the ESP input pin I need to be sure this pin has a pull-up resistor.
According to the Beginner's guide to the ESP8266 GPIO 0-15 all have a built-in pull-up resistor.
My questions are:
  • Is the internal pull-up resistor connected to the GPIO after boot by default?
  • If not, how to configure input to activate internal pull-up on the start?
  • Or it is necessary to use external pull-up?
Re: open-drain (open-collector) on the input: is external pull-up necessary
#2 Post by ThomasB » 09 Nov 2019, 04:22
No.
Keep in mind that there are some GPIO that are pulled high and low for boot configuration. See https://espeasy.readthedocs.io/en/lates ... on-esp8266
The pull-up option is chosen in the device's plugin.
Sometimes an external pull-up is needed (depends on the device). When using external pull-ups (or pull-downs) be sure to observe the special boot pin states.
PetrJakes
#3 Post by PetrJakes » 09 Nov 2019, 08:42
Where to find this option in the ESPEasyMega?
#4 Post by TD-er » 09 Nov 2019, 10:13
PetrJakes wrote: 09 Nov 2019, 08:42
Depends on the plugin.
For example the switch plugin does have a pull-up checkbox in its configuration.
You can also set the gpio boot state in the "hardware" tab.
PetrJakes
#5 Post by PetrJakes » 09 Nov 2019, 10:36
Yes, I know those settings.
I would like to configure: "Devices => Generic - Pulse counter" - but there is not setting/definition in the menu for pull-up/down
In the "hardware" tab, you can configure GPIO as an input, but similar situation: not option to configure pull-up/down.
#6 Post by ThomasB » 09 Nov 2019, 19:25
Since the counter plug-in does not have a pullup option you should install the external resistor. Couple minutes work, done.
PetrJakes
#7 Post by PetrJakes » 09 Nov 2019, 21:29
Yes, until you have to do it 50 times :D
I have made some experiments.
  • Hardware Settings => GPIO boot states: PIN14 set as an input
  • Devices => Task Settings: Device: Generic - Pulse counter => Sensor GPIO ← Pulse: GPIO14 (D5)
  • water meter open-collector output connected to the GPIO14 and GND
  • analyzer and oscilloscope connected to the GPIO14 and GND
I was really amazed about the results (screen shot below).
  • When no output pulse from the water-meter, there is 3.22V on the GPIO14
  • When output pulse, signal to the 0V for about 50ms (exactly as described in the water meter technical list)
Can somebody here explain, why is 3.22V detected on the ESP (NodeMCU) input, when no pull-up (external nor internal) connected/set for the PIN14?
#8 Post by ThomasB » 09 Nov 2019, 21:47
It is your lucky day. The counter plug-in enables the internal weak pullup by default. See _P003_Pulse.ino
PetrJakes
#9 Post by PetrJakes » 09 Nov 2019, 21:58
See _P003_Pulse.ino
Do you mean this?:
pinMode(Settings.TaskDevicePin1[event->TaskIndex], INPUT_PULLUP);
Anyway, thanks for your comments. Do you think it is good to report/request the pull-up/down issue to the
https://github.com/letscontrolit/ESPEasy/issues/new ?
In the Tasmota SW, for example, there it is possible to define:
  • Counter1 - Counter Input
  • Counter1n - Counter sensor, no pullup resistor
#10 Post by ThomasB » 09 Nov 2019, 22:45
Do you mean this?: {snip..snip}
Yes. The chosen input is configured with pull-up.
Do you think it is good to report/request the pull-up/down issue ...
You are free to do that. FWIW, I'm not a good person to ask about requesting new features because of my stubborn opinion about solving the ongoing stability issues first.
Users browsing this forum: Bing [Bot] and 91 guests
