Hello gurus,
I kind of locked myself out from two Esp Easy devices in my summer house. The reason is that I didn't change the default "Client IP block level" setting in Esp Easy. I end up on a different subnet when I connect to my network via my VPN, and ESP Easy says my IP is blocked. I do however have access to a Raspberry PI via ssh on the correct network and I can use a http command line client to connect to ESP Easy that way.
The question is how I can submit a form with httpie and change the Client IP block level setting to "Allow All" so I can gain access to ESP Easy the normal way again.
Best regards,
/David
Configure ESP Easy from the command line with httpie or similar
Re: Configure ESP Easy from the command line with httpie or similar
Hmm I was sure I did add a command to switch it off, but I cannot find it.
What you could try to do is install a text-based browser on your Pi, like lynx or links. (two different packages, not me trying to remember the name )
Found the command: clearaccessblock
Not sure if it will be accepted from the network though (maybe serial only, which would make sense)
I forgot about links. Solved it. Thanks!TD-er wrote: ↑09 Nov 2019, 10:18 Hmm I was sure I did add a command to switch it off, but I cannot find it.
Users browsing this forum: Bing [Bot] and 39 guests
