Newbeee - wants to use ESP Easy on a sailing boat
zuchi238
#1 Post by zuchi238 » 05 Dec 2019, 22:26
Some facts:
- Got my hands on ESP8266 D1 mini
- Understand Arduino a bit but read about ESP Easy, thought it would be easier to connect to Raspi (incl Openplotter) on my boat.
- Found out how to flash and was able to flash my D1
- But now I can not find the AP Wifi to finish the configuration (=connect to my home Wifi)
Do not know where to start, as I have re-flashed the card 4 times by now.
Hope anybody (much smarter) can briefly use his brainpower and put me on a "fixit" path.
Thanks,
Bart
zuchi238
Re: Newbeee - wants to use ESP Easy on a sailing boat
#2 Post by zuchi238 » 06 Dec 2019, 08:33
Anybody smarter then me out there who could help?
Bart
Flying Domotic
#3 Post by Flying Domotic » 06 Dec 2019, 10:05
Hi!
You normally should see some new AP starting with ESPxxxx. Is this the case?
You may also want to have minimum debug connecting to USB port with e terminal (either with Arduino IDE, Platform IO or any terminal like Putty). I'm pretty sure that knowing that's happen inside will help debug.
Hope this helps,
#4 Post by TD-er » 06 Dec 2019, 14:39
The included flasher may also help in setting the WiFi credentials via commands sent over the serial port.
