change rules after mega-20191130 ?
adval40
#1 Post by adval40 » 18 Dec 2019, 22:38
in software version mega-20191104 the following works perfectly
in software version mega-20191130 the following does not work anymore
do I have to change anything in the rules settings ?
I cannot see the temperature on lcd
I can't put uppercase in lcd it's shows only lowercase characters
On System#Boot do
 gpio,2,0
 timerSet,1,10
On Rules#Timer=1 do
 LCD,3,1, temperatuur [woonkamer#temperature]
timerSet,1,10
adval40
Re: change rules after mega-20191130 ?
#2 Post by adval40 » 19 Dec 2019, 00:48
one problem is solved
must be
LCD,3,1, 'temperatuur [woonkamer#temperature]'
but
LCD,3,1, 'TEMPERATUUR [woonkamer#temperature]'
shows temperatuur 23.0 on display
I cannot show capital characters
#3 Post by TD-er » 19 Dec 2019, 14:28
Indeed the rules parameter parsing has been changed.
So now you need to wrap parameters in quotes if they contain a space or comma.
The parameters should be given to a plugin without change of case, so if the LCD command does not keep the case in its parameter, then that's a bug.
adval40
#4 Post by adval40 » 19 Dec 2019, 18:23
is this rule correct ?
but the output is
temperatuur 23.8
is this a bug ?
#5 Post by grovkillen » 19 Dec 2019, 18:38
Yes that's a bug. @TD-er: seems like we lower cased the output and not the original string.
#6 Post by ThomasB » 19 Dec 2019, 19:06
The bug is due to the introduction of parseString() in the LCD plugins (P036_FRAMEOLED & P012_LCD) a couple weeks ago. This function does a toLowerCase() on the arg strings.
#7 Post by TD-er » 19 Dec 2019, 21:40
ThomasB wrote: 19 Dec 2019, 19:06 The bug is due to the introduction of parseString() in the LCD plugins (P036_FRAMEOLED & P012_LCD) a couple weeks ago. This function does a toLowerCase() on the arg strings.
Thanks, will have a look at this.
#8 Post by TD-er » 19 Dec 2019, 22:16
Users browsing this forum: Ahrefs [Bot] and 104 guests
