Rules On System#Boot
Petit_Malin
#1 Post by Petit_Malin » 20 Dec 2019, 14:32
Hi everyone,
I set up ESP01S with relays to manage my pilot wire for my heating. As you know the problems of unexpected restarting "Hardware watchdog".
I wanted to set up a rule of return in the state for the GPIO0. To do this on restarting by using a variable with a "Generic - Dummy Device".
Except that my rule is applied even if the condition is false.
Here is the rule:
On System#Boot do
timerSet,1,10      //Set Timer 1 for the next event in 10 seconds
On Rules#Timer=1 do
  if [switch#Switch]=1 and [dummy#value]=0 // Test condition
    gpio,0,0 // Power ON on GPIO 0
And This is a second rule to interact with my Domotic:
on radia1_on do //Jeedom request to Power ON
   gpio,0,0     //Power ON GPIO0
   TaskValueSet 2,1,0  // Set Dummy/Value to 0
on radia1_off do //Jeedom request to Power OFF
   gpio,0,1 //Power OFF GPIO0
   TaskValueSet 2,1,1 // Set Dummy/Value to 1
:!: when i remove the first rule, if the GPIO0 was ON at reboot the Dummy/Value is correct (set to 0) and the GPIO0 set to 1
FYI weirdly the states are reversed on ESP01S (0 to ON and 1 to OFF)
Tested with ESP_Easy_mega-20191113_normal_ESP8266_1M and ESP_Easy_mega-20180914_normal_ESP8266_1024 (the last is more stable on unexpected restarting)
Would anyone have an idea :roll:
Re: Rules On System#Boot
#2 Post by TD-er » 20 Dec 2019, 15:18
Why not set the GPIO state in the System#Boot event?
Then you know for sure no other event has happened before you made the test.
#3 Post by grovkillen » 20 Dec 2019, 15:25
I need to understand your setup. Do you have a physical switch or is the switch plugin used for the relay?
Petit_Malin
#4 Post by Petit_Malin » 20 Dec 2019, 16:00
TD-er wrote: 20 Dec 2019, 15:18 Why not set the GPIO state in the System#Boot event?
Thank's for you replys.
Because i don't no if it was ON before a unexpected reboot (See the details below)
grovkillen wrote: 20 Dec 2019, 15:25 I need to understand your setup. Do you have a physical switch or is the switch plugin used for the relay?
Ok more details:
I use a Domotic system (Jeedom) to control 4 heaters with 4 Oregon temperature sensor, for each one i have 4 ESP01S + Relay conncted to the pilot wire of the heater
On the Jeedom i have a scenario:
Example for the Room1 : If Temp room1 (Oregon temp sensor) is <20 then "http://IP_of_the_ESP1S/control?cmd=event,radia1_on" (action to power ON the heater)
On the ESP01S i use 2 devices : 1 x "Switch input - Switch" to control the GPIO0 and 1 x "Generic - Dummy Device" to have the last state on a unexpected reboot
So with the rule if the ESP01S reboot unexpectedly, it will check the last state and return if he needs it
I hope it's more clear ;)
This is the ESP01S + Relay that i use
#5 Post by grovkillen » 20 Dec 2019, 19:49
On System#Boot do
 GPIO,0,[dummy#value]
That would do it right?
Petit_Malin
#6 Post by Petit_Malin » 20 Dec 2019, 20:19
grovkillen wrote: 20 Dec 2019, 19:49
On System#Boot do
Nice try and so simple, but... it doesn't work.
Test: Set Power ON on ESP01 => Value and state = 0 if i power off and power on, at boot the GPIO0 change to state 0 (normal is the rule defined)
Set Power OFF on ESP01 => Value and state = 1 if i power off and power on, at boot the GPIO0 change also to state 0 :evil:
It's weird...
What i see on devices the Value and state are twice on 0 on the test Power OFF, as if the second rule had been played:
It's the only way to set and change the value of the dummy...
Edit: Not at all, i set Power OFF on ESP01 => Value and state = 1, deleted the second rule, power off and power on, at boot the GPIO0 change also to state 0 (and the Value and state are twice on 0)
Something else, to work with ESP01S the relay need to be shorted with a resistor (100 Ohms) between GPIO0 and Vcc and shorted with a cable between CH_PD and Vcc
Is there a cause and effect link ?
Edit2: Ok I think I have found out why : i have changed the first rule to see what append to this :
On System#Boot do
timerSet,1,30      //Set Timer 1 for the next event in 30 seconds
On Rules#Timer=1 do  //When Timer1 expires, do
To have time to see the value, and ohh surprise the dummy/value return to 0 even if he was set to 1
Is it normal ?
Petit_Malin
#7 Post by Petit_Malin » 21 Dec 2019, 12:40
Finally it's normal, settings will be lost during a power OFF("Hardware watchdog") but not during a manual reboot (warm reboot)
I had already thought of a solution via the domotic Jeedom :
Store the state in a virtual on Jeedom during the ON/OFF request with a reverse action http from ESP01S
And check in a scenario Jeedom the state between the relay and the virtual
on radia3_on do //Jeedom request to Power ON
   SendToHTTP #IPJeedom#,80,/core/api/jeeApi.php?plugin=virtual&apikey=#APIVirtual#&type=virtual&id=#VirtualIDState#&value=1 // To set the state 1 in a virtual Jeedom
on radia3_off do //Jeedom request to Power OFF
   SendToHTTP #IPJeedom#,80,/core/api/jeeApi.php?plugin=virtual&apikey=#APIVirtual#&type=virtual&id=#VirtualIDState#&value=0 // To set the state 0 in a virtual Jeedom
Other discussion found on the forum about that: viewtopic.php?t=5692
Hoping that we can do it in future versions
Users browsing this forum: No registered users and 96 guests
