Sensorupdate faster than 1 second?
Gnassel
#1 Post by Gnassel » 22 Jan 2020, 18:29
I love the ESPeasy project. Thanks a lot.
Currently I have a application with a hx711 board + 4 weighting Sensor.
For my iPhone I made an iOS application that ask for values every 500mseconds (Json).
Works stable and fine so far.
Is is somehow possible to update the sensor mor often than 1 per second?
This would make my application more accurate.
Frank
Re: Sensorupdate faster than 1 second?
#2 Post by grovkillen » 22 Jan 2020, 19:27
You would need to compile that yourself then. Currently only once per second for the official builds.
#3 Post by TD-er » 22 Jan 2020, 19:52
You should also look in the timing stats page to see how long it takes to perform a reading.
I doubt it is possible to do it at a higher frequency.
Gnassel
#4 Post by Gnassel » 23 Jan 2020, 07:52
Thanks a lot for you fast support.
Timing looks good - as I understand-
Read HX711 2ms
Loop: 229ms
I will now try to find the relevant lines in the code a compile a new one.
Frank
#5 Post by TD-er » 23 Jan 2020, 13:29
You can also test with the rules to trigger multiple taskrun calls.
As a hack you can cause some sub-second delay by calling the LongPulse_ms command (see: https://espeasy.readthedocs.io/en/lates ... -available )
This will block for as long as set.
Gnassel
#6 Post by Gnassel » 26 Jan 2020, 16:03
Thanks a lot.
Setting an output pin with
Longpulse_ms
Connected via wire to an input pin, and trigger an action by a change
Works for me.
Maybe there is a software solution, but I am happy for now.
Frank
Domosapiens
#7 Post by Domosapiens » 26 Jan 2020, 23:31
Gnassel wrote: 26 Jan 2020, 16:03 Thanks a lot.
Longpulse_ms
Works for me.
Frank
Smart Frank !
