PCA9685 timed dimming from FHEM
boerny_007
#1 Post by boerny_007 » 25 Jan 2020, 03:41
Hi Guys,
i've bought a PCA9685 for my stair lightning.
now i'd like to dim every channel up to 100% (4095 steps) from 0% in 2 seconds.
Thats what I can do by the normal pwm command (if i use the onboard GPIOs of the ESP)
pwm GPIO#,4095,2000
As I've seen in the wiki there is no 3rd parameter for the timing and even when i set a higher step it wouldn't dim up - it sets this hard.
The command is
pcapwm PIN,4095
So how could i do solve this? Any ideas?
The goal would be a command from FHEM to the ESP - connected to the PCA9685 which is dimming up smoothly from 0 to 100 % in 2 seconds.
Börny
Vitalik
Re: PCA9685 timed dimming from FHEM
#2 Post by Vitalik » 07 Feb 2020, 21:06
without an additional plugin there is no way to do this
You can add to the library
for this example
http://arduino.ru/forum/pesochnitsa-raz ... ent-473165
Rub87
#3 Post by Rub87 » 04 Jul 2021, 21:59
I found the same limitation for the pcapwm function.? It would be cool to have the same ‘fade’ possibility then if one was using an onboard pin.
Users browsing this forum: No registered users and 41 guests
