I currently use a rules script which acts on a variable
I also use a rule which act on a timer
what happens if these get triggered at the same time?
will one fail to execute, will they be queued>
On Watermeter#Count do
On Rules#Timer=1 do
The reason i ask is the resoltion of the timer is on a second base so chances are big that within that same second something else gets triggered
can rules process multiple actions
Re: can rules process multiple actions
There is a (small) queue for the events, so they should be handled in the end, but sadly there is a chance an event may get "lost" if lots of events happen at the same time.
Also the queue with events will not be dealt with all at once. Only a single item will be processed in a loop, so there is no guaranteed time between handling of events.
Users browsing this forum: Bing [Bot], Google [Bot] and 90 guests
