[Solved] Device: Generic - System Info - Vcc always -1
dampa
#1 Post by dampa » 04 Mar 2020, 17:09
Hardware: WeMos D1 pro
ESPeasy version: mega-20200222
If I select 'Input VCC' as one of the options, it always returns -1. Taking a dive into the code, I see in _P026_Sysinfo.ino starting at line 198
    case 3:
# if FEATURE_ADC_VCC
      value = vcc;
# else // if FEATURE_ADC_VCC
      value = -1.0;
# endif // if FEATURE_ADC_VCC
which always causes -1 to be returned.
BUG??
Re: Device: Generic sysingo - Vcc always -1
#2 Post by ThomasB » 04 Mar 2020, 18:01
To use the VCC option you must flash with a firmware file that has "_VCC" in its name. For example:
ESP_Easy_mega-20200222_test_ESP8266_4M1M_VCC.bin
Or if you self compile you need to configure the FEATURE_ADC_VCC flag in your build settings.
dampa
#3 Post by dampa » 04 Mar 2020, 22:24
Thanks Thomas!
Other than the fact the OTA update hosed the WeMos and I had to flash it to a blank.bin then couldn't figure why I couldn't get into it (Duh blank.bin!!) Once I flashed it with the VCC version and was able to reload my settings (Yea! I did something right by backing them up before starting) It is now workig fine.
Users browsing this forum: No registered users and 104 guests
