Hello!
is there any way to make two Wemos D1 board talk to each other using serial communication used by Reyax Lora or HC-12?
I know I can receive messages from over 10 kilometers away using Reyax module with Arduino Nano.
I would prefer using Espeasy more than arduino because I can access it then with my phone using wifi, and it just seem more easy to use and modify than hard coding everythin to arduino.
Espeasy and Reyax Lora or HC-12 communication
Re: Espeasy and Reyax Lora or HC-12 communication
The only Lora support we currently have in ESPEasy is using the Microchip RN2483.
That controller is still in development, but I have some dev boards running here for the last few weeks now and it does seem to work quite well.
I have it running via TTN, so not sure if you can also use those with direct node to node communication. (TTN uses LoRaWAN, not LoRa and uses gateways)
Later I will also add support for the SX127x and SX126x chips, but then you need to have quite a real time response, so maybe that can only be done well on ESP32.
Users browsing this forum: Bing [Bot] and 108 guests
