Send a message to LCD via HTTP command
@irvb
#1 Post by @irvb » 16 Mar 2020, 13:08
Git Build: mega-20200310
Following this : viewtopic.php?t=6411
I try to send a message to my espeasy oled screen via http.
My http command : http://192.168.88.82/control?cmd=event,remotetime
my rule to activate :
on remotetime do
 Pulse,12,1,500
 Pulse,13,1,500
 OLED-1,3,0,%vcc%
gpio 12 and 13 connected to TWO leds juste to confirm that command arrive well !
display configured as :
Display - OLED SSD1306 name : OLED-1 GPIO-4/GPIO-5
Nothing change , no line filled.
When it boots.
Lcd shows msg " ESP Easy"
I launch the http command , the leds are pulsing , but nothing change on lcd !
log :
168268: EVENT: remotetime
168292: ACT  : Pulse,12,1,500
168293: Command: Pulse
168795: SW   : GPIO 12 Pulsed for 500 mS
168798: ACT  : Pulse,13,1,500
168799: Command: Pulse
169301: SW   : GPIO 13 Pulsed for 500 mS
169325: ACT  : OLED-1,3,0,3.02
169328: Command: OLED-1
I try
OLED-1,on
 OLED-1,clean
 OLED-1,0,0,%vcc%
without help ...
After that i try to send the command from Tools , command menu
weird answer :
OLED-1,0,0,TEST
response :
NEXTION075 : WRITE = 2,0,3.02
Ok
But nothing change
OLED-1,off response : NEXTION075 : WRITE = off
Ok
Same things with commands clean or on !
Any idea thanks ;)
Re: Send a message to LCD via HTTP command
#2 Post by grovkillen » 16 Mar 2020, 13:40
OLED-1 isn't a command. Which OLED plugin are you using?
@irvb
#3 Post by @irvb » 16 Mar 2020, 15:01
I names my oled screen as OLED-1
Display - OLED SSD1306 is the device
I try this morning,in Tools command, the command lcd without help ...
But now i know where is my mistake .
Of course it's OLED,<row>,<col>,<text>
Thanks for yr help !
Code :
on remotetime do
 Pulse,12,1,500
 Pulse,13,1,500
 //OLEDCMD,off
 //OLEDCMD,on
 OLEDCMD,clear
 OLED,1,1,12345678
 OLED,2,1,ABCDEFGH
 OLED,3,1,12345678
 OLEDCMD,clear
 OLED,4,1,ABCDEFGH
 OLED,5,1,12345678
 OLED,6,1,ABCDEFGH
#4 Post by TD-er » 16 Mar 2020, 15:10
Are you using the OLED plugin, or Framed OLED?
If it is the Framed OLED plugin, please see its documentation here: https://espeasy.readthedocs.io/en/lates ... #p036-page
Maybe refreshing before submitting may also help ....
Saw you already fixed it :)
