How to communicate between two esp8266
Sasch600xt
#1 Post by Sasch600xt » 26 Mar 2020, 13:38
Hello World (represents my coding skills :)),
I use a bunch of ESPs with MQTT OpenHAB Controller to my IPSymcon Housautomating System.
All works great !
Now i have special needs:
I have one ESP with 2 Buttons connected to an MCP23017
and another ESP with 2 relais connected also to an MCP23017
i would love to push button1 on ESP1 and send it to ESP2 to toggle relais1 (one button push = relais on, next button push = relais off)
same for button2.
Both ESPs are in the same Wifi.
So do i need to set an second cotroller for this need or is there a simple solution ?
Thank you so much for your help an i hope you are all OK in these days
Sascha
Re: How to communicate between two esp8266
#2 Post by grovkillen » 26 Mar 2020, 15:31
Since you already have the MQTT broker up and running, why not use it? You can send commands over MQTT. I'd use event calls to the recipient side (relay unit).
Sasch600xt
#3 Post by Sasch600xt » 26 Mar 2020, 18:00
Thank you for your help :)
so far i did try a lot but could not get it to work.
i was reading the "rules tutorial" aswell.
Ist it all possible only by using rules ? (MQTT Controller is set)
I did try this:
ESP1 with buttons:
on System#Boot do
monitor,mcp,1
on mcp#1=1 do
Publish,"LichtgrHalleVorne","1"
ESP2 with relay:
on LichtgrHalleVorne=1 do
mcpgpio,1,0
So probably i do a lot wrong here ?
Thanks for help!
Sascha
Sasch600xt
#4 Post by Sasch600xt » 27 Mar 2020, 08:41
ok, i got it to work :)
i used an MQTT generic input in "devices"
and the rule looks like:
on MQTT_INPUT#LichtgrHalleVorne=1 do
if [plugin#mcpgpio#pinstate#1]=1
mcpgpio,1,0
mcpgpio,1,1
so this provides the toggle feature i was looking for.
YAY :)
#5 Post by grovkillen » 27 Mar 2020, 08:56
Yes that is probably the most generic way. It's also possible to post to the cmd topic of that particular unit. But using MQTT import you can have any number of units listen to any topic.
iron
#6 Post by iron » 27 Mar 2020, 11:12
Unless you do not want to involve MQTT and enable the ESPEasy P2P Networking. You will have 2 units 1 and 2
Unit 2 :
on System#Boot do
monitor,mcp,1
on mcp#1=1 do
sendTo,1,LichtgrHalleVorne,1
Unit 1:
mcpgpio,1,0
here:
https://www.letscontrolit.com/wiki/inde ... nd_Publish
-D
-D
Wiki
#7 Post by Wiki » 28 Mar 2020, 00:40
I do have tp correct a little bit. Beside the fact that the syntax is wrong for current mega release (I don't know which release iron runs), I don't know exactly since when, but in the current version of ESPEasy Mega you may not use SendTo not like this:
iron wrote:
27 Mar 2020, 11:12
But instead you have to use
  SendTo 1,'event,LichtgrHalleVorne=1'
to get the desired result
refer to: https://github.com/letscontrolit/ESPEasy/issues/2724
Sasch600xt
#8 Post by Sasch600xt » 28 Mar 2020, 18:14
ok, thanks a lot for all the answeres :)
no i try something simular which is not working at the moment.
i use an PCA9685 to have some PWM outputs.
i changed the range in plugins from 0 - 4096 to 0 -100 which is enough for my needs.
now i have an MQTT_INPUT plugin where the topic is "Dimmer" and the value i called "Dimmer1"
i am not sure about the sytax now ?
this is not working:
on MQTT_INPUT#Dimmer1 do
PCAPWM,0,[plugin#MQTT_INPUT#Dimmer#Dimmer1]
at least
seems to be ok as trigger but my PWM signal goes down to "0" always.
so somehow i can not send the value "Dimmer1" which is from 0 - 100
Sasch600xt
#9 Post by Sasch600xt » 28 Mar 2020, 18:43
got it !
this was the right syntax:
PCAPWM,0,[MQTT_INPUT#Dimmer1]
Users browsing this forum: Google [Bot] and 11 guests
