First time query gpio status not working
Hello all
When I send an HTTP request to get a GPIO pin status for the 1st time after boot the answer is empty
It is only after setting status at least once that GPIO status request gets a valid response
Is there a reason for this?
Martin
Martin
Re: First time query gpio status not working
From what I remember this is specific to one GPIO (0?)
Have you tried the same on a different GPIO ?
-D
-D
-D
Have you set 'Send Boot State' in the switch-device ?
Otherwise the state is sent first, when it has changed.
hi all
yes, i did set the boot state to output low... but i forgot to reboot
after rebooting it worked fine
thanks for your help
regards,
martin
regards,
martin
by the way... why is D0 not in the GPIO boot states ?
i see
but it does not seem to be a problem when used as output, right ?
No it's no problem, as long as you don't mind it being high during a reboot.
Users browsing this forum: Bing [Bot] and 69 guests
