Syntax
Sasch600xt
Syntax
#1 Post by Sasch600xt » 30 Mar 2020, 18:00
i am not sure about the Syntax (again :()
i do not have the device at home, so i have to make sure the code is working when i upload it to the device which controls some big gas heaters.
What i try to do is an emergency plan when my houscontrolling software crashes.
So in the case MQTT is disconnected i want the heaters to switch on and off between 15-16 degree untill MQTT Broker is online again.
Is this the right code ? Or would you guys change it ?
on MQTT#Connected do
timerSet,8,0
on MQTT#Disconnected do
timerSet,8,60
On Rules#Timer=8 do
if [Unten#Temp]<15
mcpgpio,1,1
if [Unten#Temp]>16
mcpgpio,1,0
timerSet,8,60
Thank you so much for your help !
Re: Syntax
#2 Post by TD-er » 30 Mar 2020, 18:44
The timer will not be restarted when the temp is 15 .. 16 degree.
I would not use an timer for this but just run it on every minute.
Also, what is the state if the ESP is not powered?
Sasch600xt
Re: Syntax
#3 Post by Sasch600xt » 30 Mar 2020, 18:57
but it should run once in a minute while MQTT Broker is offline.
after MQTT broker is online it should not run at all.
So the timer set was wrong ?
is this better ?
timerSet,8,0
timerSet,8,60
On Rules#Timer=8 do
timerSet,8,60
if [Unten#Temp]<15
mcpgpio,1,1
if [Unten#Temp]>16
mcpgpio,1,0
So with this code will it switch the IO to 1 under 15 degree and to 0 above 16 degree only while MQTT is disconnected ?
This would be the goal :)
Re: Syntax
#4 Post by grovkillen » 30 Mar 2020, 20:44
Try this instead:
timerSet,8,0
timerSet,8,60
On Rules#Timer=8 do
timerSet,8,60
 if [Unten#Temp]<15
  mcpgpio,1,1
  mcpgpio,1,0
Sasch600xt
Re: Syntax
#5 Post by Sasch600xt » 30 Mar 2020, 21:09
thank you but this would trigger the heaters too often.
temp is an float with 2 decimals.
so with your code the heater would switch on at 14.99 degree and switch off at 15.00, am i right ?
i need one degree buffer (<15 ON and >16 Off)
Re: Syntax
#6 Post by grovkillen » 30 Mar 2020, 22:22
Ok then your first suggestion work. If you need that buffer.
Re: Syntax
#7 Post by TD-er » 30 Mar 2020, 22:42
Using timer is OK, but I would suggest to store the state of the MQTT in a variable.
So on an event for connected/disconnected you can set this variable to 0 or 1 and periodically you just check this variable.
This makes the code much more simple.
And if you just test it every minute, there is no harm in running it on the clock time event. This way you can't forget to enable it again.
