Neopixele as status-indicator
Psi
#1 Post by Psi » 31 Mar 2020, 21:31
Hi there,
I had the idea to use a neopixel to visualize the state of the ESP.
Something like
* green: connected to wifi
* blinking: try to connect to wifi
* cyan: AP-Mode active
I've done it with a rule:
// Enable AP Mode on Flash-Button press
on FlashBtn#State=1 do
  WifiAPMode
// Blink blue while trying to connect to wifi
On System#Boot do
  NeoPixel,1,0,0,200
  TaskValueSet 12,1,0 // Init LED on
  TaskValueSet 12,2,0 // Init AP Mode on
  timerSet,1,1
On Rules#Timer=1 do
  if [dummy#on]=0
    NeoPixel,1,0,0,150
    TaskValueSet 12,1,1
    NeoPixel,1,0,0,0
    TaskValueSet 12,1,0
  timerSet,1,1
// End blink after connected
On WiFi#Connected do
  if [dummy#ap]!=1
    NeoPixel,1,0,0,200
    timerSet,1,0
On WiFi#Disconnected do
  if [dummy#ap]!=1
    timerSet,1,1
// cyan on AP Mode
On WiFi#APmodeEnabled do
  TaskValueSet 12,2,1
  NeoPixel,1,200,200,0
On Wifi#APmodeDisabled do
  Reboot
Seems to work so far but let me know if one can do it in a better way :)
Greets
Re: Neopixele as status-indicator
#2 Post by grovkillen » 31 Mar 2020, 21:43
Great! We should add that to the documentation.
chemmex
#3 Post by chemmex » 13 Jul 2020, 17:07
Any chance to blink the LED faster than once a second?
#4 Post by TD-er » 13 Jul 2020, 17:12
Not using rules.
Also even if the rules could handle a timer with sub-second resolution, it would not be a good idea to trigger it via rules.
I guess the best way would be to add a new command to the Neopixel plugin to set a flash frequency. (and one to stop/disable it)
chemmex
#5 Post by chemmex » 13 Jul 2020, 17:14
Totally agree
Users browsing this forum: Google [Bot] and 67 guests
