I have had a problem for some time. I'm not sure if it's an espeasy or domotic problem.
my diagram:
LED----mcp23017----espeasy~~~~domoticz
espeasy settings:
device: Switch input - MCP23017
Enabled: check
Port: 9
Send to Controller: check
IDX: 7
Controller: Domoticz HTTP
Home settings:
device: Light / Switch
On Action: http: //172.16.70.199/control? Cmd = mcpgpio, 9.0
Off Action: http: //172.16.70.199/control? Cmd = mcpgpio, 9.1
the effect is such that the domoticz indicator and the LED flash all the time on / off / on / off / on / off .... and so all the time.
when I use gpio instead of mcp23017 the layout behaves the same (on / off / on / off / on / off).
Does anyone know what is wrong?
Espeasy mcp23017 Domoticz problem
Re: Espeasy mcp23017 Domoticz problem
Seems like you have a dot instead of a comma between 9.0 / 9.1
Should be
mcpgio,9,1
mcpgpio,9,0
-D
Should be
mcpgio,9,1
mcpgpio,9,0
-D
-D
