hello
Dear colleagues, is it possible to configure the "Switch Button Type - Push button active low" option in the "Switch input - MCP23017" device?
This option is available for GPIO in board configuration, but not available in mcp23017.
I want the momentary short-circuit of the mcp23017 pin to ground causing its state to change permanently and the next short circuit to return to its initial state.
just like a bistable relay.
Thank you for your time.
MCP23017 Switch Button Type
Re: MCP23017 Switch Button Type
That option is not built into the plugin. But you have described a Push-On / Push-Off switch function, which can be emulated in Rules.
That is to say, an event rule could be called each time the switched is pressed. Then a dummy var can be toggled (inverted) with each press event. The dummy var's new state can then be used in other rules or sent to your controller.
It's a very good idea. I think I can easily do it, but I don't know how to send the variable status to domoticz from the rules level? Can you suggest something?
Users browsing this forum: No registered users and 83 guests
