Why can't I set the interval for at dummy to 0?
mrwee
#1 Post by mrwee » 11 May 2020, 21:13
I can see that the minimal interval is 1 sec. But how can I just publish the value when it's updated? I don't wan't it a fixed interval. Is this by design?
Re: Why can't I set the interval for at dummy to 0?
#2 Post by grovkillen » 11 May 2020, 21:32
If you want it to be updated by event you need to use rules.
mrwee
#3 Post by mrwee » 11 May 2020, 23:05
Hmm. I'm setting the dummy variable in a rule, but I need to publish it's value only when changed to ThingSpeak on Controller 2. Already have MQTT on Controller 1. Can't seem to find an example of that :?
#4 Post by grovkillen » 12 May 2020, 04:09
You would use "TaskValueSetAndRun" and it will update and publish that task.
mrwee
#5 Post by mrwee » 12 May 2020, 12:45
Ok. thanks. But I assume that since I cannot set the interval to 0 in the GUI, it will still publish by iself, or ?
mrwee
#6 Post by mrwee » 12 May 2020, 12:51
mrwee wrote: 12 May 2020, 12:45 Ok. thanks. But I assume that since I cannot set the interval to 0 in the GUI, it will still publish by iself, or ?
Just answering myself: Not if I disable the Publish to controller :D
mrwee
#7 Post by mrwee » 12 May 2020, 21:04
Can seem to get either TaskValueSet + taskRun or TaskValueSetAndRun to work with two controllers.
My setup:
ESP_Easy: ESP_Easy_mega-20200426_normal_ESP8266_4M1M.bin on an original D1 mini Pro 2.0
Controllers:
Tasks
Test rule
On mqtt3#Value1 do
 TaskValueSetAndRun,5,1,[mqtt3#Value1]
If "Send to Controller 1" and "Send to Controller 2" are disabled, then only Controller 1 gets data by using either TaskValueSetAndRun or TaskValueSet+TaskRun, nothing is sent to Controller 2 (ThingSpeak).
Re-enabling "Send to Controller 1/2" resumes sending data at the >=1 sec interval, but I'd like to only publish the data when MQTT import picks something up.
#8 Post by TD-er » 13 May 2020, 08:52
mrwee wrote: 12 May 2020, 21:04 Can seem to get either TaskValueSet + taskRun or TaskValueSetAndRun to work with two controllers.
Hmm, that sounds like a bug.
If you 'run' a task, it should call the connected controller(s)
Only way you may not see it, is when the controller has a queue of 1 and another task is also sending data to it. (given the interval is similar or lower than the sending interval)
mrwee
#9 Post by mrwee » 13 May 2020, 12:27
That possible. But even when sending one value every 30 minutes to both controller, it fails so it does not seem to be related to the queue filling up. So I agree that it sounds like a bug. I'll log it on github.
Users browsing this forum: No registered users and 43 guests
