Why can't I set the interval for at dummy to 0?
I can see that the minimal interval is 1 sec. But how can I just publish the value when it's updated? I don't wan't it a fixed interval. Is this by design?
Re: Why can't I set the interval for at dummy to 0?
If you want it to be updated by event you need to use rules.
Hmm. I'm setting the dummy variable in a rule, but I need to publish it's value only when changed to ThingSpeak on Controller 2. Already have MQTT on Controller 1. Can't seem to find an example of that
You would use "TaskValueSetAndRun" and it will update and publish that task.
Ok. thanks. But I assume that since I cannot set the interval to 0 in the GUI, it will still publish by iself, or ?
Can seem to get either TaskValueSet + taskRun or TaskValueSetAndRun to work with two controllers.
My setup:
ESP_Easy: ESP_Easy_mega-20200426_normal_ESP8266_4M1M.bin on an original D1 mini Pro 2.0
Controllers: Tasks Test rule
If "Send to Controller 1" and "Send to Controller 2" are disabled, then only Controller 1 gets data by using either TaskValueSetAndRun or TaskValueSet+TaskRun, nothing is sent to Controller 2 (ThingSpeak).
Re-enabling "Send to Controller 1/2" resumes sending data at the >=1 sec interval, but I'd like to only publish the data when MQTT import picks something up.
My setup:
On mqtt3#Value1 do
TaskValueSetAndRun,5,1,[mqtt3#Value1]
Hmm, that sounds like a bug.mrwee wrote: ↑12 May 2020, 21:04 Can seem to get either TaskValueSet + taskRun or TaskValueSetAndRun to work with two controllers.
If you 'run' a task, it should call the connected controller(s)
Only way you may not see it, is when the controller has a queue of 1 and another task is also sending data to it. (given the interval is similar or lower than the sending interval)
That possible. But even when sending one value every 30 minutes to both controller, it fails so it does not seem to be related to the queue filling up. So I agree that it sounds like a bug. I'll log it on github.
Users browsing this forum: No registered users and 104 guests
