Rules using 'OR"
Dick60
Rules using 'OR"
#1 Post by Dick60 » 20 May 2020, 10:59
According the WIKI I can you the 'OR' statement in rules.
on test do
if [test#a]=0 or [test#b]=0 or [test#c]=0
event,ok
event,not_ok
I adjusted the example to my needs but it does not work. Can anybody help me around?
I have 2 switches I can make them 1 or 0. Depending the status it will (de-)activate the generalswitch.
On generalswitch do
if [switch1#State]=1 or [switch2#State]=1
gpio,0,0
gpio,0,1
Re: Rules using 'OR"
#2 Post by grovkillen » 20 May 2020, 11:04
What version?
Dick60
#3 Post by Dick60 » 20 May 2020, 11:48
Sorry forgot to mention, the latest one 15052020
#4 Post by TD-er » 20 May 2020, 13:27
Try printing the switch state into a logentry, just to make sure you compare to the correct value and also to see if you even get into that part of the rules.
For example is there a task named 'generalswitch' ?
You refer to it in the On ... do part
Dick60
#5 Post by Dick60 » 20 May 2020, 14:18
no there isn't a 'generalswitch' task. What I read in the wiki is that it is possible to use this kind of rule. Wrong intepretation. So what si the approch for me, do you have an example for me how to het this working?
Dick60
#6 Post by Dick60 » 20 May 2020, 15:40
is this the way to continue???? It does not work but advise please.
On switch1#State do
event,generalswitch
On generalswitch do
gpio,0,1
gpio,0,0
#7 Post by grovkillen » 20 May 2020, 16:49
Try this (GPIO 14 just as an example):
On switch1#State do
GPIO,14,[switch1#State#Z]
Or inverted:
On switch1#State do
GPIO,14,[switch1#State#!Z]
Dick60
#8 Post by Dick60 » 20 May 2020, 17:28
this is working
On switch1#State do
but how can I use the 'OR'' statement
if switch1=1 or switch2=1
the Generalswitch must be set to 1
#9 Post by Ath » 20 May 2020, 17:33
You're almost there, something like this should work:
On switch1#State do
  event,generalswitch
On switch2#State do
  event,generalswitch
On generalswitch do
    gpio,0,1  // Turn on
    gpio,0,0  // Turn off
Dick60
#10 Post by Dick60 » 20 May 2020, 18:03
Thanks a lot for all the support. Now it makes sence to implement it in my project.
Have a great day.
Users browsing this forum: No registered users and 33 guests
